Question about Westinghouse " 46"" Class - LED - 1080p - 120Hz - HDTV LD-4655VX"
LED TV has black shadow in corner
There is a dark shadow near the lower left corner of the TV. It initially would come and go, now it seems to be permanent. Please advise-
I have a Sharpe LC-60LE600U. The power went out on it. What power board works on that TV. The lower left hand corner has a black spot, too. Will the power board fix the black spot as well?
Power Board wil not fix black spot. the spot is caused from lamp failure. Led strip has at least one LED out, takes out the whole section. Go into trouble shooting to verify. After so many start ups with the black spot, the TV will not turn on in TV mode.
Sep 22, 2016 | Sharp Aquos Televison & Video
Visio E701I-A3 TV backlight part number
The following picture symptoms indicate a bad LCD panel, and NOT a bad back light or board:
-One side of the picture is darker than the other
-Picture has horizontal line(s)
-A dark, cloudy spot spreads across the picture
Jan 22, 2016 | Televison & Video
Dark shadow in lower left of screen
i guess there is some problem with your panel. make sure you show it to the nearest service centre
Jul 22, 2013 | Toshiba 37HL67 37 in. LCD HDTV
My acer aspire 3539 laptop has a persistent black shadow appearing on the lower right of the screen and when pressed upon there isn't any liquid effect unlike the other parts.. please help!
1.Since darks are persistent,the LED backlights are problem.If it still has time left on the warranty, ask for replacement.Else call technician and replace LED backlights only.
If this helpful, please give a testimonial and vote by pressing button thumbs up.
Sincerely, Thiyaga
Aug 28, 2011 | Acer Aspire 3935-6504 Notebook
4gb pmp350-4 mp3 player touch screen. Screen is back only can see a shadow images of icons try to reset screen is still very dark. can this be fix?
From the main menu of you mp3 player touch the lower right corner of the screen, then touch the lower left side of the screen, then press the lower middle section of the screen. Then press the lower left side of the screen again and then the lower middle screen. Then press the lower left side of the screen until the screen brightens. From there you should see your screen to further assist yourself...Your welcome(:
Dec 27, 2010 | Polaroid Juke Jam PDP602 MP3 Player
Dark shadow in middle of TV when turned on . Last...
the cold cathode lamp of your tv is nearly to be busted and needs replacement..tnx
May 20, 2010 | ViewSonic N4785p 47 in. LCD TV
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Westinghouse " 46"" Class - LED - 1080p - 120Hz - HDTV LD-4655VX" Logo
50 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
