Question about Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
The unit shorts out. The unit tipped over on a carpeted surface and now it shorts out causing the electrical panel to be re-powered. Can it be fixed or is it best to change the unit? .
Once the unit tipped over a large spark near the control panel lit up and the blew the relay in the electrical box. I switched the relay back on, plugged it in and it keeps shorting out. I opened the unit and disconnected the wiring to reach the control board but don't see any shorts unless it affected the board. Where and how can I fix this unit please ? It's a Noma digital model ew7507ce, type kr775071SEP with serial # 74715. thank-you
3 Suggested Answers
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
SOURCE: noma ew7507ce manual
Timer is not identified.
Noma is a recognized brand name that is licensed to many different product manufacturers for a variety of different products including timers.
Check resources below:
1) Add a comment with clear description of timer, and/or post a photo on flickr and include link to photo
2) Open following link to see various Noma timers and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/images/NOMA-logo-1200.gif
3) If you have different product than a timer, for example an oil-burning radiator or electric baseboard heater then re-post question on fixya with clear description of product for possible research and information
Posted on Oct 03, 2011
Why does my dirt devil max upright vacuum shock me? When im making laps, vacuuming.
if it is during vacuumming carpets it may be static electricity generated by the plastic head over the carpet
if it happening n hard surfaces , take it in for a safety check as there may be a loose wire touching metal and causing you the shock
Jul 30, 2017 | Dirt Devil Vacuums
What would cause a 2005 ford explorer sports trac to not have turn signals or brake lights and it blows fuses when we put them in.
You have a shorted wiring harness, check at the rear of the vehicle undercarriage first for a damaged wiring harness that is cut or worn through on frame or other metal surface. There is no magic fix for shorted wiring, just hard work and close examination.
Feb 15, 2017 | 2005 Ford Explorer Sport Trac
WILL NOT CHARGE
I THINK THE BATTERY NEEDS REPLACING (INSIDE)...OR A BAD CIRCUIT BOARD.........IT JUST IDEALS I HAVE
Apr 15, 2014 | Garmin nuvi GPS
Water in the power head
Make sure machine is un plugged. Open up the power head that you are worried about and put some uncooked rice inside then close it back up, wait a few hours (or day if you want more reassurance). The rice will soak up any moisture trapped underneath anything or stuck in corners etc. Re-open use a cotton que-tip dipped in rubbing alcohol to clean the inside, electric boards and all, large surface areas that are not electrical could be cleansed in a less tedious way. Close it up again then try plugging in and turning it on. Watch for and smell for any burning signs, if you see or smell any turn it off and unplug it immediately. That is how to dry and clean any electrical device. Hope this solves the problem.
Mar 24, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I pulled up old carpet ,but rubber backing is sticking to floor ,how to get off ??
Most rental centers have electric powered floor scrappers. There are many other ways but after a short while they all made the rental units look real good. I hope this helps you. Thanks
Nov 20, 2010 | Garden
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
Xbox 360 Console: disc is not working keeps saying open tray...
This just worked for me..... unplug all leads etc from the back of the console2_bing.gif, hold the unit 6inches from the floor (carpet surface - not a hard floor) the front of the panel facing the carpet and drop it........ If its still under warranty send it back - if not give it a go!
May 17, 2010 | Microsoft Xbox 360 Console
My electrolux O3 carpet power head keeps shorting
If your unit is like ours, there is a electrical short in the wand to Hose connection.. dont use it.. ours unit shorted out and sparks were everywhere.. burned thru the wand to the inside of it and the outside. Good thing my lovely wife wasn't touching that part. electrocution risk was Extreme. PESTER ELECTROLUX, they drag their heels when it comes to admitting and making it right.
Oct 18, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
We just started getting shocked when we turn on some of our light switches never had this happen before it started hapening right after we had lost power does anyone know what might cause this? Thanks...
Angela
It sounds like a static electricity issue to me, and if so there are many products on the market to eliminate this. The most effective are anti-static carpet spray's that can be purchased from a local carpet dealer or supply. You can research other remedies on the web.
Tip: You can create an inexpensive anti-static spray by mixing laundry fabric softener with water 50/50 into a spray bottle. Lightly mist this spray on carpets and other surfaces to prevent static buildup.
Hope this helps
Good luck...
Feb 23, 2009 | Leviton 104-05611-2WS 15A Decora Single...
Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr Logo
95 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
