Question about IBM IntelliStation M Pro 6218 PC Desktop
Can Windows 7 run reasonably well on a IBM Intellistation M Pro 6218? That is, does it have adequate horsepower for basic stuff, or undemanding CAD work.
I'm considering buying more RAM for it and a Windows 7 install disk, but I won't if it's just not worth it. I don't expect fast; I just want not painfully slow or full of glitches.
  • IBM Master
  • 2,013 Answers
I would not recommend this. The latest bios is from 2006. This machine would be under-powered for running Win7 and I'm not finding drivers for Win7
Posted on May 08, 2014
SOURCE: IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Posted on Jul 06, 2008
marketex
  • 371 Answers
SOURCE: Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
Posted on Apr 21, 2009
  • 375 Answers
SOURCE: Upgrade Intellistation Z Pro 6121 w11 to 64bit Xeon Processors
It helps if you give the right specification - the W11 is the 6221, not the non-existent 6121.
You have 2 x 2.4 Xeon in a Socket 604 package. The only CPUs these could be are the Tigerton - it certainly does support 64-bit operation, as well as VT.
You have little choice in processors - Tulsa, Tigerton and Dunnington.
The Tigerton is a little ripper! 2 x 4MB on-die cache, 1066 internal FSB, wide voltage range and low power consumption (80W).
http://ark.intel.com/Product.aspx?id=30779
You have a 4 processor 64-bit box - if it isn't poweful enough for you (and I can't see why - I run 50 concurrent VM users on less), you can only go to the 2.93 Tigerton as an upgrade. The other CPUs have more horsepower, less torque!
Don't get hung up on processor speed - for 64-bit big cache rules.
Posted on Aug 05, 2009
SOURCE: IBM IntelliStation Z Pro 6221NNG upgrade possiblity
I've just added an *nVidia GeForce 7950 GT 512 MB AGP 8x* to a ZPro 6221 running Windows 7 Ultimate 32 bit with no problems. Aero looks good.
Posted on Dec 15, 2009
chalkperson
  • 147 Answers
SOURCE: i have installed 2 (1gb) memory modules and 2
Check Spec of twoo 512's. Use the following link for assistance. Also fread attached PDF file (IBM Redbook). Ian. Good Luck.
Posted on Jan 13, 2010
IBM INTELLISTATION M PRO does not power up
Have you tried any troubleshooting? It is most likely the System board or power supply. You could take a known good power supply and swap it out to see if it will turn on, if not it's the system board.
Jan 02, 2014 | IBM IntelliStation M Pro 6218 PC Desktop
Can it run windows 7 reasonably well
need the spec plzz but I think I can run if you are running vista..then it will run windows 7 to
Nov 20, 2013 | IBM IntelliStation M Pro 6218 PC Desktop
Beeping & no display
beeping at boot means different things. google beep codes if you have another pc?. could be ram failure, processor, mobo failure , etc. Or..it could be a flat battery-which can stuff up the bios and wont boot. So check the mobo batt isnt flat first and reset the mobo bios- jumper pin. Hope that helps.
Oct 14, 2013 | IBM IntelliStation M Pro 6218 PC Desktop
Usb boot intellistation
Are you sure you have the USB set as a bootable device? I mean is there boot software on the USB device?
Apr 19, 2012 | IBM IntelliStation M Pro 6218 PC Desktop
Intell Station M Pro Type 6218 Booting time Processer Fan sound will more and system will not started
If your CPU fan is blocked your computer won't start. Change your CPU fan. That's your problem if i understand corectly.
Mar 24, 2011 | IBM IntelliStation® M Pro 6218-1GU PC...
This: http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx is a link to the system requiements. As for memory, I can't find out if it's DDR or DDR2. If you don't know either, try downloading a tool called CPU-Z. That should display DDR or DDR2, and I can then recommend something.
As for the graphics card, you could try to get an ATi 9000 series card somewhere.(maybe buy one on ebay? I doubt they still sell them new...) I have one too, in an old PC, and while it doesn't run any new games, it's fast enough for the casual user.
Dec 07, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
I have an IBM Intellistation M Pro (6218-cto; it
I can't installation windows Xp to my PC IntelliStation M Pro 6218,my SCSI drive not detect in Windows setup
Oct 05, 2009 | IBM IntelliStation M Pro 6219 PC Desktop
Aug 05, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM IntelliStation M Pro 6218 PC Desktop Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
