Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I can't change from economy mode to standard mode on my leisure bay spa
  • Dream Maker ... Master
  • 1,631 Answers
Bad button on the topside panel.
Posted on Jan 29, 2014
My Dream maker Odyssey spa is stuck on economy mode. There is no way for me to see to change it to standard mode.
Try pressing 'TEMP' then 'LIGHT'. You may have to do this a couple of times.
If you don't have a 'TEMP' button, either the temperature up or down will also work.
There are three modes, ECONOMY (EC / ECO / ECON), SLEEP (SL / SLP) and STANDARD (ST / STD). For everyday use keep it on STANDARD mode.
Cheers,
Ian Kime
Ian Kime Hot Tub Sales Repairs and Servicing
May 02, 2017 | Standard Pool & Spa
Older leisure bay tub. only a few buttons on topside panel work as they should. temp control buttons switch from economy to standard,cant raise or lower temp. Topside panel or control board?
Top side control. 90% sure by your description of problem. Buy the topside, plug it in and try it before you do full install. If it doesn't work you can return it. Most places won't take back a PC Board.
Apr 25, 2017 | Leisure Pool & Spa
Spa fault codes what is ecn flashing on my spa and not warming up
Economy mode is the energy saving mode of your spa that only filter water and doesn't maintain the temp.
Depending on type of spa you need to change it to standard mode
Jul 08, 2014 | Pool & Spa
Leisure bay spa , will not go from SL mode , temp stays @ 82 degrees?
This appears to be the sleep mode, which is a freeze protection mode. You need to get your owner manual out and change the mode to standard so it will heat.
Rod
US Parts Center
Jan 05, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Control panel for spa and pool and spa heaters reads "SEr". cannot turn the temp up or down. Spa will not come on.
This sounds like the spa has been put in the Standard Economy mode.
When your spa is in this mode almost nothing works as it is in a freeze protection mode.
Change the operating mode back to standard and it should work just fine in the future.
US Parts Center
Sep 24, 2013 | Hayward Pool & Spa
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Apr 06, 2013 | Washing Machines
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
Mar 13, 2013 | Balboa Instruments Pool & Spa
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
439 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
