Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Cycle complete BUZZER
How can I disable the loud buzzer which sounds at the end of wash or dry cycle?
  • 8 more comments
  • BuzzHater Nov 15, 2007
    Exact same problem
  • Lucycat Nov 20, 2007
    The buzzer is so loud I have a heart attack every time I do laundry. How can I turn this thing off??
  • Anonymous Dec 19, 2007
    My first step was to e mail Frigidaire. Of course, they cannot legally recomend disabling any part of their machines. Looking here is step 2.
    Next is to look inside and see if I can find the offensive buzzer and do something to it.
  • Anonymous Mar 07, 2008
    Heart attack every time
  • mcvermont Apr 15, 2008
    Yikes! same situation here- wakes the babe every time... Has anyone figured out a way to dismantle it yet? I'm hoping....
  • Anonymous Jul 17, 2008
    this buzz noise is ridiculously loud. I can only do laundry when my baby is awake and it quite frustrating so i'm like every one else looking for a solution to eighter minimize or eliminate the noise totally.
  • memejo10177 Aug 15, 2008
    I'm not a complete moron, so I do know how to remove my clothes after the wash cycle and dryer cycle is complete. So why does the BUZZZZZZZZZZZZZZZZZ need to be SO LOUD AND LONG that my dogs howl and everyone in the house wishes that they were hard of hearing? We called Frigidaire and was told it could be muffled, but if we turned it off we would void the warranty. We were told to go online, look up the manual and locate where the buzzer was and follow the instructions. NOT THERE!!!
  • mufsi Dec 02, 2008
    We're considering buying this model but looking at this buzzer problem will not take the chance. Hasn't frigidaire provided some assistance in shutting off the buzzer or at least lowering the volume?
  • Anonymous Jan 18, 2009
    Never mind the baby, the buzzer on my Fridgidaire Gallery Series stackable washer dryer combo can wake the dead. Sadly, there doesn'[t appear to be any way to disable it short of opening electrical panel up and mucking with the wiring.
  • jenkinsdjtg May 11, 2010
    thnx! i will try it.
    New Friend:
I too was terribly annoyed by the volume of the buzzer on the Frigidaire Gallery set that I have in my apartment. Because there is no way to turn it off with a switch I decided to look around and managed to find a technician manual that had some diagrams of where the buzzers are located.
I managed to turn both of them off and then put together a manual with pictures labeled detailing what you need to do. It takes about 5-10 minutes and requires nothing more than removing 6 screws and then pulling and taping off 2 wires but make sure you turn the power off first :)
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Hopefully this makes things easier on someone...
Posted on Jul 16, 2010
  • 1 more comment
  • sadiesmith Sep 29, 2010
    You can disconnect the dryer wire just as you do the washer. You just have to follow it to the other end.
    Thank you so much for your pictures!!! You have no idea how happy I am to have the buzzers silenced. Whoever thought it was a good idea to do this and not have a switch to turn it off should be made to listen to it all day long, every day.
  • wongnog
    wongnog Mar 24, 2012
    You are right! I tried to pull the dryer buzzer wire out with pliers as the washdud538's instructions said, but it was too difficult. Didn't even see sadiesmith's comment, but instead pulled out the other end of the dryer buzzer wire which did have clips and taped that off. This was way easier than I thought it would be!
  • omnilife
    omnilife Jun 06, 2012
    Thanks so much ;> good pictures! - end of Torture!
I just completed this using the instruction link posted here dated 12/23/2007 solution #2.
There are two different buzzers, one for the washer and one for the dryer. There are two wires leading to each black box as described in the link. You know you are looking at the right black box if it doesn't have a user dial directly corresponding on the outside of the panel.
For the washer, I unplugged one wire directly plugged into the washer buzzer and then taped with electrical tape.
For the dryer, I had to follow the wire from the dryer buzzer to one of the wires leading to the dryer timer/dial mechanism (sorry I don't know the correct name for it but I think you know what I mean) and I unplugged one of the wires connected to the dryer time/dial and then taped with electrical tape. There was not an easy way to disconnect the wire from the dryer buzzer as it was wired inside the box.
The wires can be unplugged without cutting any. So, if you are concerned about warranty issues, it can be untaped and replugged without any even knowing.
TIP: My fingers are small enough but I was not strong enough to pull the wires off so is used some pliers wrapped in cloth to unplug.
Stromski: There is no way to get to the dryer connection without removing the panel. There are a total of 6 screws to remove and they are all located in front. There are two panels, the large front panel that must be removed first. This comes off completely with removing two screws.
The second is the control panel and comes off with the four screws as described by Gordon R dated 1/17/2008 in the the link "For the challenged mechanics, you do not have to remove any of the knobs. Remove the front angled plate between the washer and dryer. Then you will see the silver screws (one on each side on a tab) and the small black screws (one on each side on the very end holding the end plate on).
After removing the screws, pull the bottom out a bit, and then pull the whole unit down and out. I found the right side was sticky. When I took a good look at the tabs on the left side, I saw how they were attached and the type of pull out from the bottom and pull down and then away motion I needed."
This second panel (the control panel with the knobs) only comes forward staying hinged from the bottom. It takes a bit of jiggling but it will come forward, a little from the bottom and then more from the top. There is no need to try and remove this completely. Also, it was a nice way to get some dust vacuumed out.
Good luck! I too had called Frigidaire two years ago and they gave me the same response about not being able to do it, warranty issues, etc. I can now do laundry late at night without waking up the neighbors because our windows are open. With two dirty toddlers, we have more laundry than ever, as of today I am now happily buzzer free!
Thank you Fixya and all who responded to this! Woo hoo!!!!
Posted on Aug 17, 2008
  • 3 Answers
I disabled the buzzer today and made a few mistakes along the way, but here's the easy way.
First, take a look at the parts manual, ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995482162.pdf, page 6 item 14 shows the buzzer.
Remove the two screws beneath the control panel
Then the two screws holding up the white diagonal back panel
Then the five screws holding up a metal plate behind the white panel
Then two more screws that hold in the back panel
Gently, but with authority, push the control panel down and out.
The buzzer is easily accessible and the wires can be pulled with needle nosed pliers
Most importantly, turn off the power before working on the unit. I was cocky and thought I could do it without turning off the power but when reassembling, something touched something else and I got a big spark, cloud, and a little burning around the frame.
Fortunately, it looks like the unit is still working.
/Doug
Posted on Dec 07, 2008
    New Friend:
Thx dstke for posting the link to the diagrams. Really helps to locate the wires.
Just one note: pulling the control panel down and out was a lot harder than I thought. It took help from a flat screwdriver, which left a couple marks. Not too visible though and quietness is well worth it.
Posted on Feb 20, 2010
Try here: http://servicetechhelp.com/discus/messages/2801/18992.html?1177391649
Posted on Dec 23, 2007
I managed to get one of the washer buzzer wires unplugged and taped off. I did not take the console off, as the above link suggested, but worked backwards with a mirror (NOT EASY!).
I still have not gotten to the dryer buzzer. The exhaust duct runs right up behind the console on that side. I will take a closer look at the parts diagram to get the console off. The unit is in a closet, so I hope the screws for the console are accessable from the front.
SOURCE:
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
Buzzer at end of dryer cycle too loud. Can I turn it down or disengage it?
Usually, there is a front panel control for buzzer volume or turn it off completely. If nothing there, you will need to locate the buzzer and either remove and tape the wires or if the unit has an opening, stuff some paper into the opening.
Sep 26, 2009 | Dryers
Whirlpool washer has begun to make a loud buzzing sound when the
This machine has an end-of-cycle buzzer built in. It may be that it just started working.
Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer end of cycle buzzer
disconnect the BUZZER wire from the Timer
Sep 16, 2008 | Crosley CDG6000 Gas Dryer
Loud buzzer Model FEX83...
SIMPLE! behind the dash board are screws simply take screws out ane the buzzer shouid be hooked to the timer. there are two ways to do it either cut the wire if you plan never to use the buzzer again or if you want to just unplug it!
Jan 20, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
9,292 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
