Need a burner screen for a colman 5014-751 15,000 btu
Where can i get one
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: I need to know what
15,000 BTU
Posted on Sep 02, 2011
Fridgidaire stove clock not keeping correct time
Clock logic can not be changed replace the whole board
just lets you change the time will not let you slow it or speed up
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
My colman forced air propane heater is burning very yellow is there a way to adjust it to make it right? or is that normal
No, it's not normal.
There are two things that can cause the problem: Low gas pressure or poor air intake at the air shutter control on the burner(s). The air intake may simply be clogged with dust and lint. In which case, you can clean it with a vacuum that has a hose and crevice tool attachment. Vacuuming the burners will also help.
As far as the low gas pressure is concerned , be sure your tank has enough gas to carry the heater. It may be running out. Gas pressure will have to be professionally checked.
The cleaning part, you can handle.
Hope this helps resolve your problem.
Feb 26, 2011 | Coleman Propane Forced Air Heater...
Colman fernace blinking code 9 what is this
there should be a trouble code index on the panel that shows the wireing diagram good luck
Oct 03, 2009 | Coleman Propane Forced Air Heater...
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Oct 03, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
