Question about Toyota Bp- Toyota Forklift
Toyota 7FBCU15 code CO-1 no drive
The lift has been stored for 2 years. After charging multiple times there is hydraulic function but not drive.
2 Suggested Answers
dttech
  • 4803 Answers
SOURCE: toyota sienna 2006
Your first mistake is having a "diagnosis" by a parts counter sales person.
I wrote an article about his very subject. You might find it helpful. Click the link below to read the article:
What Else Could Be Wrong?
Then, you did not list the code that you got the first time, so there is no way of knowing if the parts sales person told you correctly on the first time or not.
Diagnostic Test Code (DTC) P0058 is defined by SAE J2012 as "HO2S Heater Control Circuit High Bank 2 Sensor 2" (SAE J2012 is the standard by which all vehicle manufacturers must define the "generic" or "non-vehicle specific" diagnostic test routines necessary to properly diagnose and repair their cars.)
To understand what is going on here, it is very important to understand that this code definition DOES NOT tell you to replace the oxygen sensor. This is an oxygen sensor heater CIRCUIT code. The heater circuit on your vehicle includes the battery voltage (B+) supply circuit and the heater control (HT) circuit to the Powertrain Control Module (PCM). Failure of either of these circuits will cause DTC P0058 to set.
The B+ circuit consists of the BLACK/RED wire at the oxygen sensor connector which gets its power from the EFI 2 fuse (10 Amp) located in the engine room junction block. There are several things powered by this fuse and there are several splices and branches in the wire. Voltage MUST be checked at the O2 sensor connector.
The control circuit for the Bank 2 Sensor 2 heater is the WHITE/BLUE wire that runs only from the O2 sensor connector to connector E7 PIN #33 at the PCM.
BOTH of these circuits must be check to make sure they are not shorted to ground and that they have continuity to their connections at both ends.
Also, after repairs are made, all engine control codes must be PROPERLY cleared using an appropriate scan tool in order to make the check engine light turn off and to prevent additional problems with the engine control system. Many uneducated do-it-yourselfers will tell you to disconnect the battery cables to accomplish this. That is NOT the correct way to do it, and this can cause voltage spikes that can damage sensitive computer equipment in your car and possibly cause fault codes to set in several of the computer modules in your vehicle.
Many do not believe that this is possible. If you want proof, pull the plug on your home PC and plug it back in a few times and see if it doesn't wreck your hard drive....
Posted on May 15, 2012
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
Tip
Caterpillar Fault Codes
CID code Name
1 Injector? 1
2 Injector, cylinder number 2
3 Injector number 3
4 Injector number 4
5 Injector, cylinder number 5
6 Injector, cylinder number 6
7 Injector number 7
8 Injector number 8
9 Injector number 9
10 Injector number 10
11 Injector number 11
12 Injector number 12
13 Injector number 13
14 Injector number 14
15 Injector number 15
16 Injector number 16
17 The fuel shut-off valve
18 The fuel control valve
19 Bypass valve accelerator
20 Device change timing of fuel injection
21 Position Sensor Engine
22 Sensor fuel injection advance
23 Drive Racks
24 position sensor rail
27 is a variable geometry turbocharger number 1
28 Drive with variable geometry turbocharger number 2
41 Power ECU (electronic control unit) 8 V DC
42 Valve inclusion nozzles
70 contact with the parking sensor
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor pnevmozapuska
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
96 Fuel level sensor
98 Oil level sensor in the engine
99 The differential pressure sensor on the engine oil filter
100 Oil Pressure Switch Engine
101 pressure sensor crankcase gases
102 turbo pressure sensor
104 Oil pressure turbocharger
105 temperature sensor intake manifold
106 sensor input air pressure
Pressure sensor 109 of coolant downstream of the engine
110 Coolant Temperature Sensor Engine
111 level sensor, engine coolant
The differential pressure sensor 112 to filter engine coolant
124 gearbox oil level
126 differential pressure sensor on the oil filter transmission
127 Oil Pressure Switch gearbox
138 Mode Switch low traction
139 Solenoid tip ago
140 Solenoid tip forward
141 Eco Mode Switch
142 position sensor door to clean the radiator
143 contact pressure sensor control unit neutral
144 horn relay reverse
145 power supply circuit 12
146 Mode Switch hitch
147 pressure sensor lock-up clutch
148 pressure sensor in the hydraulic stroke
149 Three-way solenoid stabilization system of the implement when driving
150 Speed Sensor trambovatelya
151 Solenoid trambovatelya
152 diagnostic lamp control systems course
153 speed sensor right drive motor
154 RPM Sensor left actuator motor
155 solenoid switching stroke
156 Solenoid right turn in reverse (electronic display)
157 Solenoid left turn in reverse (electronic display)
158 Solenoid right turn forward direction (electronic display)
159 Solenoid left turn forward direction (electronic display)
160 Relay working equipment paver
161 brake sensor (chassis) pedal
162 Sensor Steering Wheel
The steering angle sensor 163 rotation
164 Pressure Sensor inclusion nozzles
167 Sensor charging voltage of the alternator
168 Electric system
171 of the ambient air temperature sensor
172 temperature sensor in the intake manifold
174 Fuel temperature sensor
175 Temperature Sensor Engine oil
177 oil temperature sensor Gearbox
190 RPM Sensor engine crankshaft
191 sensor output speed gearbox
248 data channel of Caterpillar
249 data channel J1922 SAE (Society of Automotive Engineers)
250 data channel J1708 / J1587 SAE (Society of Automotive Engineers)
Block 252 calibration
253 Personal chip control unit
254 electronic control unit
256 Map adjusting engine performance
257 Level detonation
258 sensor crank angle
259 set via software point fuel injection
260 oxygen sensor in the exhaust gas
261 the fuel injection timing calibration
262 circuit sensor supply 5 V
The power circuit 263 digital sensors (8 or 12)
264 pedal revolutions reduction
265 Input circuit stopping the engine, user-defined
266 Input circuit dry scroll engine (without fuel injection)
267 Chain input remote control signal Safe Stop engine
268 Error programmed parameter
269 circuit sensor supply
Code 270 cable computerized monitoring system (CMS)
271 Sound the alarm
272 sensor has exceeded the allowable turbo
273 pressure sensor at the outlet of the turbocharger
274 atmospheric pressure sensor
275 pressure sensor at the entrance of the right turbocharger
Pressure transducer 276 at the input of the left turbocharger
277 sensor calibration injection timing
278 The indicator light turn on the automatic control of engine speed (AESC)
279 coolant temperature in the intercooler front section
280 temperature sensor gear
281 The indicator light necessary Engine
282 Light indicator exceeding the permissible engine speed
283 Indicator Light air filter
284 Radio on EMS (electronic control system) (the signal of the engine)
285 overheating indicator light, engine coolant
286 Indicator light low oil pressure
287 Miniature digital output? 7
288 Miniature digital output? 8
289 Fuel pressure - before the fuel filter
290 pressure sensor in the pump drive engine cooling fan
The solenoid 291 engine cooling fan
292 solenoid hydraulic oil cooling fan
293 power analog output? 3
294 power analog output? 4
The control unit 295 hydraulic excavator heavy-duty
296 gearbox control unit
297 all-wheel drive system control
298 The probe brake pedal
299 position sensor gear lever
300 The primary windings of ignition coils
301 The primary winding of the ignition coil? 1
302 The primary winding of the ignition coil? 2
303 The primary winding of the ignition coil? 3
304 The primary winding of the ignition coil? 4
305 The primary winding of the ignition coil? 5
306 The primary winding of the ignition coil? 6
307 The primary winding of the ignition coil? 7
308 The primary winding of the ignition coil? 8
309 The primary winding of the ignition coil? 9
310 The primary winding of the ignition coil? 10
311 The primary winding of the ignition coil? 11
312 The primary winding of the ignition coil? 12
313 The primary winding of the ignition coil? 13
314 The primary winding of the ignition coil? 14
315 The primary winding of the ignition coil? 15
316 The primary winding of the ignition coil? 16
317 load cell
318 Right knock sensor
319 Left knock sensor
320 RPM Sensor / injection timing
321 Key switch reset / diagnostic confirmation
322 engine stop switch
323 The indicator light engine stop
324 Alarm lamp
325 detonation caused by the ignition system
Detonation System 326
327 Wrong number of knock sensors
328 Wrong number of cylinders of the engine
329 Error Link
330 Login with contact sensor propane content
331 Ignition Switch
332 keyboard switch
333 switch alarm
334 Reserve output
335 solenoid screw scraper
336 switch engine control
337 Remote Switch emergency stop
338 Relay pre-lube pump motor
339 contact pressure transducer pre-lube the engine
340 solenoid shut-off air
The solenoid 341? 4 warm-hydraulic distributor
342 Auxiliary speed sensor engine crankshaft
343 injector NOx catalyst in the exhaust gas
344 Relay injection pump converter of nitrogen oxides in exhaust gases
Pressure sensor 345 of the injection NOx catalyst in the exhaust gas
346 Relay stabilization system of the implement when driving
347 solenoid feed control (working volume) motor hydrostatic transmission
348 lock switch gearbox
Solenoid 349 gearbox synchronization
350 position sensor rod lift
351 position sensor rod misalignment
352 Sensor lift lever (in the cockpit)
353 sensor lever skew (in the cockpit)
The solenoid 354? 1 lift
The solenoid 355? 1 lowering
The solenoid 356? 1 unloading
357 Solenoid No. 1 return
358 Drive pressurization of the control loop hydraulic system work equipment
359 solenoid locking lifting
360 solenoid lock lowering
The electromagnet 361 tilt lock to download
362 solenoid control the fan speed of the engine
363 Drive stabilization system of the implement when driving
364 pressure sensor piston cavity lift cylinder
365 switch for limiter
366 contact gauge semiautomatic recess
367 Switch stabilization system of the implement when driving
368 switch, automatic / manual mode transmission
369 Login with shift indicator on the gearbox
370 Solenoid floating position arrows
Solenoid 371 beep
372 solenoid opening bucket (for excavator shovel)
373 solenoid closing bucket trucks through the hinged bottom (for excavator shovel)
374 Solenoid swing brake
375 Solenoid swing brake
376 Warning stroke
377-way solenoid brake
378 solenoid automatic lubrication system of the machine
379 Pressure Sensor automatic machine lubrication
380 contact pressure transducer modulation shift gearbox
381 Contact neutral position sensor lift lever (in the cockpit)
382 lever position sensor coupling
383 position sensor coupling
384 shifter
385 contact sensor neutral position tilt (in the cockpit)
386 solenoid lifting hitch
387 Solenoid lowering hitch
388 Contact line solenoid coupling
389 The probe neutral auxiliary lever
The solenoid 390 controlling the flow of hydraulic oil through the forward clutch
The solenoid 391 controlling the flow of hydraulic oil through the reversing
392 solenoid oil supply
The solenoid 393 to drive the front wheels
The solenoid 394 controlling the flow of oil through the drive motor
395 solenoid switch actuator pressure of the front wheel
396 Light on lamp-wheel drive (AWD)
397 contact pressure transducer feed pump
398 pressure sensor in the front wheel drive
399 sensor to the control lever-wheel drive (AWD)
400 The secondary windings of ignition coils
More Fault Codes HERE Caterpillar DTC
on Dec 20, 2016 | Cars & Trucks
Toyota Echo Central Locking Problems
you have a faulty sensor
call your dealer and ask the some time the answer those question with no charge $$ !
Apr 05, 2015 | 2000 Toyota ECHO
Interchangeable parts
Canadian parts differ from Us and Mexico. Using a US part will decertify Canadian motor vehicle standards. I wouldn't try using anything but Canadian parts
Mar 19, 2017 | Toyota Corolla Cars & Trucks
1999 Toyota Camry V6 with 60,000 miles won't start
Could be the battery also the alternator AutoZone does this check for free other places charge about 45$ to do that check
Apr 01, 2010 | 1999 Toyota Camry
2000 Toyota Corolla P0171
When the fuel trim is high teens or in the 20s then its the MAF that the problem. If fuel trim is normal, 2-5 then its the O2 sensor.
MAF-
Buy "Electrickleen" at the parts store.
Remove the MAF sensor, WHILE COLD, and blast the wire inside with cleaner.
The "hotwire" gets gummed up and changes the resistance of the wire so you get a bad input to the ecu and it trys to lean out for a rich condition that doesnt exsist.When it cant adjust anymore it trips the po171 code.
Jun 01, 2009 | 2001 Toyota Corolla
Hydraulic lifts on back door quit working
Sorry you can not repair the hydraulic life, your going to have to replace it. You can buy new ones at the Auto Zone or Parts Source and both parts store can give you the how to do the job your self.
It's only going to take you less then 5 min to change one side at a time with the use of a flat head screw driver.
Good luck and hope this helps, most of the time the parts person can help you change the back door lift.
May 05, 2009 | Volkswagen New Beetle Cars & Trucks
KX-T7731 messed up the co button
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
TI 84 will not graph multiple functions simultaneously
Turn off transformers. Go to apps and go all the way down until you reach transformers then hit enter. Then a menu should appear and hit uninstall that should fix it.
Sep 09, 2008 | Texas Instruments TI-84 Plus Calculator
Toyota Bp- Toyota Forklift Logo
145 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
