Question about Ovens
Gas burners won't stop the initial spark - Ovens
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
Why won't burners stay on
Alguien puede ayudarme con el diagrama electrico del horno imperial
gracias
Jun 20, 2013 | Imperial ICVD-1-H Turbo-Flow Gas Single...
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Aug 29, 2011 | Ovens
Gas stove with electric starters for the burners. One keep clicking after it lights. How do you stop the clicking?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 02, 2011 | Thermador Professional Series PO301...
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Gas Burner spark on other location
When you turn a burner to the light position, all burners should spark. If one is not, clean burner head area where the burner is not sparking. (dirty from boil overs)
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
12 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
