Question about Power Rangers Toys
Power Rangers Zeo Pyramidas Carrier Zord assembly instructions
  • John Stewart
    John Stewart Nov 22, 2013
    The instructions show how other Power Ranger characters are arranged to make it a super Zord
Theres nothing in my printer to put the ink into
It could be that the cartridge carrier just did not move to the loading position. If you're having trouble with the cartridge carrier not moving automatically to its loading position (to install/replace cartridges) even when the printer is on and the cover is open, please follow the steps below:
  1. Unplug the printer from the power source.
  2. With the printer cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the carrier to the center of the printer.
  3. Open the latch and remove the used cartridges.
  4. Load the new cartridges. Close the latch and then the printer cover.
  5. Re-plug the printer to the power source.
  6. After going through the startup process, try to print a document to verify that the cartridges are working and installed properly.
Jan 07, 2012 | Lexmark Polaroid P310 Photo Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
I need instruction sheet for mega bloks power rangers spd 5745.
You can get the instructions for this set and loads of others at the Mega Bloks wiki site called Blok City.
If you use the link below and then go to the bottom of the page you'll find the instruction booklet for this set.
http://www.blokcity.com/wiki/index.php?title=5745_S.P.D._Zords_Deployment
Apr 19, 2011 | Power Rangers Toys
POWER RANGERS LIGHTSPEED RESCUE DELUXE MAX SOLARZORD where can i find instuctions for this item
look in the labels and/or packaging, see which company made it, contact them, they will happily send you the instructions either via Email or a paper copy in the post :)
Oct 12, 2010 | Toys
Sunlite deluxe child carrier...lost instructions
I just received the manual via PDF. Doesn't look like I can attach a file to this, so contact me with your email address. It is for the regular carrier, but they go together the same.
Mar 16, 2010 | Sunlite Bike Rack Rear Alloy Welded...
Toys Logo
22 people viewed this question
Top Power Rangers Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Power Rangers Toy Expert? Answer questions, earn points and help others
