Question about Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
Canon pixma mx350 printer ink level shows exclamation mark about the icon
The printer still allows me to print but the colour starts to fade out. I've just refilled the cartage and try to reset it, is their something I'm doing wrong?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Posted on Nov 21, 2013
  • 99 Answers
SOURCE: reseting mp210
with the printer unpluged, remove the ink cart to the right.  plug in the printer.  Press the power button and do not release the button.
Posted on May 28, 2008
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
SOURCE: Resetting the cartridge icons on MP 480 printer after refilling cartrdges
I found that if you just hold down the 'stop' button with the little red icon on it for a few seconds, it resets the ink. But the cartridge has to have the error message that says it is completely out of ink, not just low on ink. Hold it down for a few seconds until it starts processing. It will check the cartridge, and then it worked for me!
Posted on Jun 03, 2009
Testimonial: "Thank you. I will try this. "
Sak-en na
SOURCE: How do you reset ink levels on a Canon pixma mp190 printer?
you can reset low ink error by pressing stop/reset button for 10 seconds
Posted on Oct 27, 2009
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I changed ink cartriges and it won't let me print it says ink is empty. How do you reset the ink levels?
There is no reset for ink levels. When you open the cover do the cartridge lights flash indicating the cartridge is empty. This problem can arise from using compatable cartridges. Try a set of genuine cartridges and the problem will probably be solved.
May 04, 2011 | Canon PIXMA MX350 Wireless All-in-One...
I just set up my new Canon MX350 printer, and the software is already on my laptop from being installed at Futur Shop. The wireless on the printer is set up, my laptop recongnizes that it prints through...
You have to go into the control panel on your computer and select the printers and faxes icon. Then, select the printer you need to use and right-click on its' icon. Scroll down to the option which reads "use printer online" and click on it. It should now read "ready." It also must have a check mark on the top left of the icon denoting you have selected it as the default printer.
Jan 03, 2011 | Canon PIXMA MX350 Wireless All-in-One...
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Printing only b&w from a colour Canon Pixma 500
The Canon will not allow you to print with empty color tanks, or without them installed.Canon does not want the ink to dry in the printhead which would destroy he printhead.
Sep 01, 2009 | Canon Pixma MP500 All-In-One InkJet...
Colour prints coming out like draft copies - i.e. faded
Hello sir; It seem like you need to clean ink cell and print head, open top part let the cartridge move to the middle and the UNPLUG power cord you can easily to reach the ink cell to clean it.
Aug 20, 2009 | Canon PIXMA MP210 InkJet Printer
Canon PIXMA MX350 Wireless All-in-One Inkjet Printer Logo
326 people viewed this question
old marine
old marine
