Question about Honda Pressure Washer PSI 3000
Was working fine, for about an hour. Stalled checked and fuel looked low but not empty. Filled just in case and the engine started. Ran about 5 minutes then stall as out of gas. Restarted using choke and did the same. Next time would only run for seconds before stalling. Any ideas?
    Sergeant:
  • 417 Answers
Maybe your gas cap is bad an not ventin allowing air behin the fuel
Posted on Nov 22, 2013
3 Suggested Answers
SOURCE: surging and stalling
Thought it was a free advice web site? Scammin' scumbags!!!
Posted on Sep 08, 2009
eugbug
  • 479 Answers
SOURCE: engine on pressure wash stops.
Remove float bowl and check fuel flows freely from the float shutoff valve.
If this is the case, you don't whave to worry about a blocked fuel filter (Which might be in the tank)
Check for any loose electrical connections.
Try a new plug as the insulation of the plug may be breaking down when it gets got (There could be hairline cracks in the ceramic)
Posted on Jun 14, 2011
N80 start
You have to find the reason the check engine light is on. This will aid in diagnostics. Also, are you buying fuel at the same place both times?
Apr 23, 2014 | 2007 Hyundai Elantra Limited Sedan
Shuts off while driving but starts up
Sounds like it's not getting fuel. Check fuel pressure at the fuel rail. If low, make sure the pump is running. If the pump is running, but no pressure at the rail, check fuel, filter. Get back to us with result of these checks.
Jun 29, 2017 | Kia Sedona Cars & Trucks
My 2003 harley Ultra classic just started to stall out when riding and engine light comes on then runs fine again
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 31, 2012 | Harley Davidson FLHT Electra Glide...
2002 caravan stalled, faulty gas gage added fuel ran for 2 blocks, stalled added 4 more gallons non-ethanol - no start checked fuel pump fuses & relay had towed 2 miles - started fine! ideas?...
Looks like your fuel supply line has got chocked. This happens when the dirt from the gas tank comes into the fuel line when the tank is getting empty as it has happened in your case. Check your fuel filter and replace if required.
Nov 15, 2010 | 2002 Dodge Caravan
Dies after running for awhile
you have vapor lock...try a fuel stabilizer...that should fix it
Jul 09, 2010 | 1997 Jaguar XK8
Starting and running
check if the power to the fuel pump gets constant power when switched on it may have a electrical problem you may need to get a auto elect tech to help you
Aug 04, 2009 | 2004 Dodge Ram 2500
2000 mazda MX-5 1.8l
Have you checked that you have power to the coil on cranking?You may also want to check wether you have a good strong spark at the spark plug.It could be an ignition module breaking down.If you have no power to the coil you may need to change the ignition relay.Its close to the battery.
Oct 26, 2008 | 2000 Mazda MX-5 Miata
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
Car stalled twice today - once when low on fuel and at a stop sign - took foot off break and engaged but stalled- and then filled up and was going around corner and then stalled- what could it be
If the car actually ran out of gas, it could be air trapped in the fuel lines. it may take a few minutes for all the air to purge from the gas lines. The car may run rough during the process. The car should be fine after running a few minutes.
Aug 14, 2008 | 2005 Buick Century
Honda Pressure Washer PSI 3000 Logo
220 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
