Question about Humio Humidifier HU-1020 with Aroma Therapy - $.01 Shipping
Humio won't start
Plug it in - nothing happens
3 year old Essick tower D46720 sat during off season. Cleaned, filled and plugged in today and will not turn on. Lights are on; nothing happens.
The red water level light was on even though both tanks were full. The white float behind the filter WAS stuck to the bottom of the tank. I just moved it to its floating position and voila! it is working.
Nov 21, 2016 | Essick Air D46720 6 Gallon Humidifier
What would cause my humio to stop producing mist?
Low mineral content in the water.
Nov 20, 2016 | Humidifiers
Brand new. Why doesn't it work and won't mist?
if not working and is new, call your cust service for the humidifier and tell them, they will determined if u can fix or needs to be replaced, this is the only way
Humio Ultrasonic Cool Mist Humidifer Stylish Room Humidifier and Night...
Jan 05, 2016 | Humio Humidifier HU-1020 with Aroma...
Water to humidifer won't turn on.
Check if there is power to the solenoid valve, if ther is , then the solenoid is bad and must be replaced. If there is no power could be a bad humidistat or transformer.
Dec 19, 2012 | Aprilaire 600 Humidifier
I have a healthist humidifier model 4100.. I purchased my humidifier on 12/26/09 from Raindew pharmacy. So far I had no problem.But today, when I plugged the apparel, nothing haened, the motor is not...
If you've been using tap water, then you likely have hard water deposits (scale) on the heating element, which will eventually cause it to stop working. Try cleaning it with an overnight vinegar soak, or whatever is suggested in the manual if you have one. Once most of the deposits are gone, it shold work again. In the future, this will not happen if you use distilled (not to be confused with filtered) water. Good luck!
Feb 13, 2011 | Kaz 4100 1 Gallon Humidifier
My aprilaire humidifier model 500 series does not seem to kick in. I try moving the manual control when the furnace kicks in but even turning the control to the max nothing happens
Check to see if you are getting 24 volts at the transformer, if you are then bring the power directly from the transformer to the solenoid valve and see if the solenoid valve clicks open by moving the knob on the humidistat. If nothing happens then most likely the solenoid valve is bad and needs to be replaced. If the solenoid valve does work after bringing power directly to it then either tne problem is the humidistat it self or the sail switch/current sensing relay.
Jan 09, 2011 | Aprilaire 550 Humidifier
I've installed a Honeywell 220A whole house humidifier. I've wired the humidifier, sail switch, humidistat and transformer according to the directions, but nothing happens when I turn it on. No water is...
push sail switch forward by hand to see if that is the problem.
Remove two wires at humidifier and connect them if it starts than it is in wiring, humidistat, or transformer.
Oct 14, 2009 | Honeywell HE220A1019 Whole House...
Aprilaire 760 won't start
No. when you remove the front cover it will automatically disconnect the power supply. Try changing the water panel and cleaning out the orifice and filter screens located in the water lines connected to the solenoid valve.
Dec 26, 2008 | Humidifiers
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Humio Humidifier HU-1020 with Aroma Therapy - $.01 Shipping Logo
305 people viewed this question
Top Humio Humidifiers Experts
Paul Carew
Dennis
Are you a Humio Humidifier Expert? Answer questions, earn points and help others
