Question about Cosmi Flow Chart Maker Full Version for PC (22787616144)
How can i run 16-bit program on 64-windows - Cosmi Flow Chart Maker Full Version for PC (22787616144)
First I would try right clicking on the installer and going to the compatibility settings and changing the installer to use windows xp sp 2 or earlier and do the same once the program has installed. If that doesn't work Installing XP mode into your system would probably your best bet but that would take some pretty decent hardware on your system to run cleanly.
Posted on Nov 20, 2013
How do I fix this? Unsupported 16-Bit Application
You are trying to run a 32bit version program on a 64bit system, this is not allowed. Try obtaining the 64bit version of the program and load that or alternatively try CutePDF, it works well on any system.
Aug 06, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Runing windows vista body works 6 won't run it seems to be 16 bit program how can i run 16 bit program on a 64 bit oparating system
Yes, that is an annoying issue. the only solution appears to be that BodyWorks needs to offer a 64 bit program. MANY people are going to be running into this as their equipment fails and gets replaced.
Nov 13, 2011 | The Learning Company BodyWorks 6.0 Full...
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
I'm using Windows 7 64 bit & I can't Install "Bitware plus 4.0" in my computer. I see this message after starting Install: Title is: Unsupported 16-bit Application Message is: " The...
any 16 nit or 32 bit is not compatable with 64-bit operating system but yes they do make a 64 bit version of that software make sure your downloading the right version
Apr 01, 2011 | Computer Associates BitWare Plus 4.0 Full...
Unable to run on 64 bit machine.
By the looks of it, this is nothing more than a simple compatibility issue regarding the architecture of 64 bit windows. There isn't much info about the program spoken of online, so I'm going to have to assume that it is pretty old, as far as software goes.
when Microsoft released 64 bit windows (for 64 bit xp, vista, and 7 this applies), they decided that they would not implement software support for 16 bit programs. only 32 bit programs would have legacy support (most modern software is 32 bit). this means that programs that were written for much older versions of windows would no longer be able to run. This mostly applies to programs primarily intended for use on windows 95 and windows 98, for which a lot of software was 16 bit.
I'm sorry to say that there is really no way around this, it is simply the way technology is, and support for old legacy code has to continually be cut from newer, more advanced operating systems. I'd recommend finding an alternate, more up to date program to use.
hope that helps :)
Apr 01, 2011 | H&R Block Kiplinger's Home Legal Advisor...
I really love this program. I have recently upgraded my computer to Window 7 64 bit and this program runs 16 bit is there any way I can make windows 64 bit compatible with this program.
There is a way of having micrografx draw install and run properly on windows 7 64-bit and also 32bit
The discovery is that most of these programs are not really 16 bit
If you want check out the website at
http://micrografxdraw64bit.site40.net/
If you want more evidence of this let me know
Feb 03, 2011 | Micrografx Small Business Graphics and...
Years ago I bought Easy Translator 4 deluxe at Staples for $10.00. I teach school and this has been a life savor for communicating with parents. This summer I bought a new laptop which comes with windows...
Trying running the Install program in Compatibility mode and running the program in Compatibility mode for Win XP it should allow that. If not it is going to be an issue of your using a 64 bit version of Windows now and your software was designed for a 32 or 16 bit environment. You could check the program manufacturer website to see if there is an update or patch for it as a last resort. 64 Bit versions of Windows don't like to cooperate with 16 and 32 bit programs even when they were programs designed to run on Windows as a platform.
Sep 20, 2010 | Transparent Easy Translator 4 Deluxe for...
I have Windows 7. Wanted to install Trophy Bass 2 and get this message. Any suggestions? --------------------------- Unsupported 16-Bit Application --------------------------- The program or feature...
unfortunately no, windows 64 bit doesn't support 32 bit or 16 bit applications so you should call the support number or go online to return the unsupported edition for a 64 bit edition (if they have one). Hope this helps.
Jan 30, 2010 | Computers & Internet
I just bought a 64 bit operating system Vista Home Premium Computer and it won't load a 16 bit software application. Is this normal? Is there anything I can do to my computer to change it from a 64 bit...
You can try running the 16 bit app in compatibility mode. Right click on the app's exe, click on properties, and select compatibility, then tick the box labeled "run in compatibility mode", then select Windows 98 from the now available drop down box.
Dec 25, 2008 | NewTek Video Toaster 2.0 (512 MB) Graphic...
O s
The four things that make 64-bit Vista inadvisable for ordinary users are:
1: No compatibility with old 16-bit Windows apps. This means ancient Windows 3.x software, which most people don't run any more, but 16-bit code can still pop up in the darndest places. Like, for instance, in the installer programs for other apps.
2: No automatic registry and file redirection, which is what 32-bit Vista uses to allow existing software to work with Vista's better user account security, even if the software wants to do admin-rights stuff to the registry and Program Files directory. Many apps still break in 32-bit Vista, but many more break in the 64-bit version.
3: No compatibility with existing 32-bit drivers. Everything on your computer will need a new driver. 64-bit WinXP is the same, and there aren't many 64-bit computers on which Vista won't at least install, but 64-bit Windows also has...
4: No support for unsigned drivers.
Jan 28, 2008 | Computers & Internet
Cosmi Flow Chart Maker Full Version for PC (22787616144) Logo
70 people viewed this question
Top Cosmi Computers & Internet Experts
Tony
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
