Question about Sony BRAVIA KDL40VL160 40 HDTV LCD TV
REF # E58699884 MY TV HAS A WASHED OUT LOOK . I RESET IT TO FACTORY SETTING IS STILL HAS A WASHOUT LOOK
Sony kdl46ex156 occasional no signal. unplugging and re-plugging the power cord temporarily fixes it
Try resetting your TV to factory Setup Below is a link to do this also Make sure You are Not restricting cooling to the TV could be causing power supply overheating. https://us.en.kb.sony.com/app/answers/detail/a_id/42994/c/65,66/
if still Not OK then Main Board probably is the answer link to a supplier below Make sure you match board ID to replacement part before ordering usually best to call and talk with their People before placing order these things have lots of variables
Good luck http://www.shopjimmy.com/sony-1-895-182-21-a-board.htm I've purchased shopjimmy before you deals no problems have a couple preferred vendors but neither list your parts available so here you Go
http://www.amazon.com/Sony-1-895-371-11-Input-Signal-1P-012BJ00-4010/dp/B011A7Q5JG/ref=sr_1_fkmr0_3?ie=UTF8&qid=1463729902&sr=8-3-fkmr0&keywords=SONY+kdl46ex156MAIN+BOARD
Feb 03, 2016 | Sony Televison & Video
As soon as the washer starts to fill with water it starts coming out from the bottom. Can you tell me what could be the problem and where can I get an owners manual or repair guide?
Follow the washout hose( the one that goes into the wall for washout) to the back of your unit, make sure the hose is connected to the machine. Or check that same hose for leaks or punctures due to vibration of the unit while in use.
Nov 10, 2015 | Washing Machines
Septic vs washout tub?
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Mar 23, 2014 | Washing Machines
How to reset my galaxy s111
Go to "settings" then to "Back up and reset" and select "Factory data reset"
NOTE: By doing a factory reset all data will be lost. Suggest to back up any data that you wish ti keep first before proceeding with a factory reset.
Ref: http://downloadcenter.samsung.com/content/UM/201206/20120608141856590/GT-I9300_UM_EU_Icecream_Eng_Rev.1.0_120607_Note.pdf
Dec 19, 2012 | YouTube Videos
How do i reset a sony wega kdf55wf655 tv?
Hello
To reset this set to its factory settings:
Press when in a Menu, to reset the settings to the factory defaults. Also user to clear Labels, Channels or Favourite Channels.
To reset the TV fully to its Factory Defaults:
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button. OK.
Oct 08, 2011 | Televison & Video
My vizio has input locked
Hello
Reset the device to its factory settings. To reset it to factory settings, enter "Setup", select 'Reset All Settings", press [=>] button to reset the TV to its factory settings. All parameters, except the parential lock will be reset to it original factory settings. If you for got the pass code, just enter its factory reset passcode [0000]; Eventhough the set will report this to be wrong passcode, input [0000] once again. This will unlock the passcode, and you have to set a new passcode. OK.
Sep 02, 2011 | Vizio VX20L 20 in. LCD TV
How do i do a master reset?
Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings.
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Ref: http://www.htc.com/www/howto.aspx?p_id=297&id=182
May 03, 2011 | HTC HD2 Smartphone
Random red washout
We had the same red "pixilation" problem with our new Vizio 47" set. Read within this site for our solution (posted by Cavanaju): Call Vizio and have them come out and replace the LVDS cable and the main board. They will have to order and bring in the parts, which will involve them unscrewing a million screws to take off the entire back of the tv and replace that calbe within it all and the main board. It will then be just fine! (I hope...we just had ours fixed 4 days ago and so far, so good...) Hope this works. Seems to be a factory defect they have had with this set. Good luck!
Jun 10, 2009 | Vizio VO47L 47 in. LCD TV
Canon Powershot S400 take blown out outdoor pictures
The onlything i can sugest you try is to reset the camera. Im not sure how to do this other then to remove the rechargable battery and the button battery. Its a little round silver disk looking thing. Let it sit over night and see if it resets. Have you tried snapping a picture from every mode? TV,AV,SCN,Manual and Auto? Do they look washed out on your computer? Can you take a picture at 640X480 (S) and upload it so i can see what it looks like? Post a link to the image.
Mar 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Sony BRAVIA KDL40VL160 40 HDTV LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
