Question about BeOne Moko
Mouse not working on MOKO Bluetooth keyboard for surface pro
Hi. I just bought a 3.0 bluetooth mouse , nexxtech and its n ot connecting to my surface pro. any ideas/?
Have you tried searching for new bluetooth devices with your computer after pressing the pairing button?
Jun 02, 2016 | NexxTech Computers & Internet
Dell XPS M1530 bluetooth wireless mouse
since it is a wireless bluetooth mouse, you should make sure that each time you restart your system make sure that the bluetoth is enabled nd working. Also see the battery check on the mouse. if you are having more than one USB port, make sure you try on them too. Hope to hear from you.
Thankyou
Mar 20, 2008 | Dell U0636 Mouse
Tip
How can I get a Bluetooth keyboard and mouse adjust for better reception
<p>Want a better keyboard and mouse get? Look in the Bluetooth receiver. Receivers can be internal (the motherboard) or external (USB). Bluetooth signals span of 33 meters or 10 meters, so a mouse and keyboard should be able to work anywhere in this area, while the receiver is not blocked and there is no interference. <br /> <p><br /> <p>1. Find your Bluetooth receiver. Each computer is different. Laptops have a small round recipient, either on the side or front of the notebook base. Desktop computers, indoor or outdoor antenna or Bluetooth "dongle" that plugs into a USB port. Check your manual if necessary. <br /> <p><br /> <p>2. Place your keyboard and mouse to the side when an aluminum casing. Newton Peripherals recommend this step because before 2009 most Bluetooth receivers were on the side of notebook computers, and the cases of aluminum and magnesium blocking Bluetooth signals. Newer laptops have one receiver in front of the cabinet, allowing for better reception. <br /> <p><br /> <p>3. Avoid placing the mouse and keyboard directly to your desktop computer. The components built in front of the computer can block or interrupt the Bluetooth signal, so put your mouse and keyboard on the side or at an angle to the computer. <br /> <p><br /> <p>4. Interference check and surface. Bluetooth uses radio waves and FM radios can interfere with the signal. Make sure the devices are not turned FM. Make sure you're not the keyboard and mouse on a metal surface or reflective surfaces because both can interfere with transmission. <br />
on Jun 26, 2011 | Computers & Internet
In the EEE starter kit for Microsoft surface pro how do I get the 24 G wireless optical mouse to connect to my surface
The mouse should have come with a wireless-receiver that connects into a USB port on your computer. Plug-in that adapter, and the mouse should be able to wirelessly-connect to that adapter.
Mar 16, 2014 | Computers & Internet
How to connect a wireless mighty mouse to a macbook pro
There should be software if it is a Apple Magic mouse, install software, then turn bluetooth on for mouse, unless your mac doesnt have bluetooth, then you need a USB bluetooth adapter.
Apr 16, 2010 | Apple Wireless Mighty Mouse
I did something to the mouse and now it will not work on a flat surface, only in the air. What did I do. I don't have the manual.
It depends what kind of mouse you have: If you have a mouse with a ball located at the bottom of it then you might of knocked it back into where the mouse operated, therefore the mouse only working in the air... OR ... If you have a sensor mouse you might of knocked it or dropped it meaning that something has happened with its controls inside leaving it only working in the air, i hope this was useful :)
Aug 28, 2009 | Gyration GO PRO 2.4 Optical Air...
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
?have 17 inch macbook pro and 24 inch apple monitor, also apple wireless mouse and keyboard. Every once in a while the mouse and keyboard lose connection but the trackpad works with the monitor along with...
If you have "good batteries" installed in the mouse and keyboard and you still have the problem- the best way is to remove the devices via the System Preference panel in your MacBook and then re-install them again. It is important that you remove them first as the system may revert to the previous connection. Good luck!
Apr 29, 2009 | Apple Wireless Mighty Mouse
Dell bluetooth keyboard/mouse bundle
i just got the bluetooth keyboard and mouse but i dont know how to get them to work. can any body help?
Jun 06, 2008 | Dell Wireless Keyboard Optical Mouse w0147
BeOne Moko Logo
88 people viewed this question
Top BeOne Cycling Experts
John Egan
John Egan
Are you a BeOne Cycling Expert? Answer questions, earn points and help others
