Question about Garden
2000 escalade hard to start
Hard to start but it does runs good once it starts
  • 3 Answers
Bad ground cable .. run a pair of jumper cables from negative baterry post to anywhere you can clip them on your motor or starter itself anywhere thats ground he whole motor is ground so anywhere .. you ll see the diffrence .. you have a bad ground cable which cant conduct the current your starter needs and its not properly charging your baterry ... your power is fine the red its all about the ground
Posted on Jan 29, 2014
Service engine light
repost with codes and you will recieve the help you want... the systems monitered by the light are all directly related to a running engine. turning over slowly could be battery or starter (cold weather does affect battery charges).
Feb 11, 2014 | 2000 Cadillac Escalade
2000 escalade wont start, changed coil ignition good fuel pump not getting a spark
crank sensors on GM's are usually pretty easy to replace and not expensive-and are usually the reason for a no spark problem.
Dec 24, 2010 | 2000 Cadillac Escalade
Security
put key in ignition in On position for exactly 10 minutes (do not start) wait til anti-theft/security light turns off. Then immediately start the car. This will reset the system
Oct 07, 2009 | 2000 Cadillac Escalade
2000 nissan maxima hard to start.
sounds like solenoid on starter is worn, replace starter.
Aug 18, 2009 | 2000 Nissan Maxima
I have a cadallic escadale. It will turn over but wont start.
The fuel pressure should be 60 to 65psi in your system with the engine not running and fuel line primed, (ignition key's to the run position). Once engine is running the fuel pressure should drop by 5psi, change the fuel filter and recheck the fuel pressure at the shredder valve. it's known for the fuel pump to fail when the gas tank runs low or out of gas, the pump will end up burning it self out since the gas is what keeps the electric fuel pump cooled. The other thing to is putting gas through the top of the throttle body to start the engine on the SEFI is a NO NO, well a BIG NO NO. it's been know for the gas in the intake to catch fire and burn up the poppet valve in the injection system causing the replacement of the fuel injection system. Keep me posted and good luck, be gald to help you get your truck running again for the july 4th. OH and it was not mentioned but did the fuel filter get replaced???
Jul 01, 2009 | 2000 Cadillac Escalade
My 2003 escalade died while on the highway now won't start battery good! But turn the key and nothing happens?
Hello<I am Ron.Be sure the battery is good by checking,or having it checked.Check the cca,and load test.If this checks out,then proceed to look for bad terminal connections and then either a burned out fusible link,or large maxie fuse.Fusible links look like a wire,but will pull apart like taffy if the are burned out.Look near a positive wire junction,most likely near battery.The fusible link will be attached there.Be sure if the battery checks bad,to check the alternator,or have it checked.If I can help,let me know.>>roniecon@gmail.com
Jun 22, 2009 | 2000 Cadillac Escalade
Can't keep my Escalade running
Have you checked the EGR Valve. Does it miss at idle or all the time?
A stuck "open" EGR Valve will make it hard to start and it will miss at idle.
It might also set your Check Engine light and give you a code P0404.
May 28, 2009 | 2004 Chevrolet Tahoe
2000 cadillac escalade won't start - radio comes on but nothing else, please help
If you are certain the battery is at a serviceable state of charge and your security system isn't interfering, the next step would be to clean the battery clamps at the battery and following the cables downward, the other ends (one will be at the starter). There will also be a stretch of cable tying the engine block and chassis together that should also be removed and cleaned thoroughly.
Turn on your headlights while pointed at some target (a wall or similar), then turn the key to the start position; if the lights dim greatly, the battery is down. If they hardly dim, then the cable paths mention before must be cleaned.
Mar 18, 2009 | 2000 Cadillac Escalade
Escalade won't start
Check to see if you have spark At the plugs.. then lemmie know. Thanks
Mar 15, 2009 | 2000 Cadillac Escalade
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
