Question about Topcon Rl-h4c Rotating Laser Level - Db Package
Topco,how do I set percentage of slope on my new laser
Manual doesn't explain how to set percentage of slope on my new rl-h4c laser
What is the slope buttons used for
If you have the standard RL-H3C then there are 3 buttons. Starting from the left there is the "height alert" then "manual" then "Power".
Height alert is a function that after the laser levels and spins monitors the position of the laser. If the laser moves more then a tiny amount then the height alert function is tripped, and the laser flashes it's lights and stops spinning (or spins slowly) to let you know the base line position of the laser has changed. Pressing the height alert button twice shuts this mode off.
Manual mode means after the laser is leveled, it completely ignores the level vials. You can turn the laser any way you want to and it will always spin and not cause any errors.
Power is self explanatory.
If it's a RL-H3CS then it has two arrow buttons, that when in manual mode, allot one axis of the laser to be manually adjusted up and down to do a manual slope.
Sep 22, 2014 | Topcon Rlh3c Rotating Laser Level W...
How do I calibrate a topcon laser ?
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series. calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-0.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-2.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-5.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-9.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-14.jpg
Aug 11, 2014 | Topcon Rotating Builders Red beam Laser...
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
Setting up duel slope laser
Put the instrument on a tripod, and line up the gun sights on top of the laser, in the direction you want the slope to be. figure out which axis your in (based on the filled in or empty wedge on the side of the laser above the glass) and then press the up or down arrow for the corresponding display screen on the keypad. Hold up or down until you've reached the percent grade you want.
Apr 08, 2014 | Spectra Precision Laser Model 722 Dual...
Percentage error
how do you set up a problem when performing percentages ?
Jan 20, 2014 | Health & Beauty
Laser won't turn on
Likely it's dirty battery contacts. Clean the contacts on the battery tray, and the coil springs in the laser, and it should start.
If not open the laser, reinsert the battery tray with good batteries and test the voltage at the battery connector at the rear of the laser.
Check for signs of water damage or corrosion.
short out the power switch, to make sure it's not the problem.
The switch circuit board, power connectors, battery tray, and motors are the only electronic parts still available for these lasers, and that is only because they share them with the RL-H3A, which was only discontinued in 2011. If none of the above will make it turn on, you'd need to find used parts, and try and rebuild it.
Jan 28, 2013 | Topcon Rl-hb Rotating Laser Level W/ls-70b
The handbrake doesn't hold the car on steep slopes, only gentler slopes - and even then I hold my breath! It's had new pads and the cable has been tightened too, but the problem's still there...
I think you should look into the possibility that your rear brake pads, and your parking brake pads are different items. Replacing one is not necessarily replacing the other. Many vehicles have different brake surfaces, and adjustments thereto, for parking brakes. Find the person who did the back brakes and ask him if there is another set of pads for the parking, and if so, did he replace those too? If they do not know, call a dealer parts department or a plain jane car parts store. I notice advance parts seems to indicate a parking brake shoe set for your car, in addition to the back brakes, but they do not sell them.
Aug 25, 2011 | 1994 Isuzu Trooper
Topcon Rl-h4c Rotating Laser Level - Db Package Logo
27 people viewed this question
Top Topcon Electronics - Others Experts
Are you a Topcon Electronics - Other Expert? Answer questions, earn points and help others
