Question about Kolpak SK8-818-CI
Refrigerator cooling defrost freezer
Lots of ice built up in the freezer. How to defrost it. What is the proper temperature for freezer
    New Friend:
  • 18 Answers
Buy a freezer thermometer from any supermarket, it has a guide.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Posted on Dec 04, 2013
The bottom of my Panasonic frig freezer NR-B29SG2 keeps forming ice making it difficult to open the bottom drawer
Confirm that the seal around the door is tight.
Confirm that the door is fully closed with no obstructions and the door alignment is correct.
Confirm no ice between door and seal.
Using a strip of paper test the tension between the door and seal around the door.
Check the freezer temperature.
It is possible that the defrost cycle has stopped operating. Usually the self defrost will prohibit proper cooling as the ice builds up on the cooling coils. Look for ice build up on the cooling coils/vent openings.
Check the freezer and refrigerator temperatures.
Hope this has helped?
Nov 07, 2016 | Panasonic Refrigerators
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
First refrigerator stopped cooling, next freezer. Seemed like it was trying to defrost but their was lots of ice built up on coils. Jen-Air side by side, counter depth model number JCB2388ARB.
Causes of ice build up on coils:
Not enough freon (leak). Coil defrost heater not working (Coils on all freezers freeze up, but you should not notice). Coil defrost timer not working. Compressor thermostat not working (or end fell out of proper location).
:o).
Jun 04, 2011 | Jenn-Air JCB2388G Side by Side...
Major ice build up on the freezer side of the side by side TFX20JRSM model RL257174. Defrosted the freezer side, seems to be working alright but the refrigerator is not cooling properly. The temperature is...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ff
Sep 26, 2010 | GE Refrigerators
THE FREEZER STOP FREEZING AT THE TOP BUT THE BOTTOM
check the evaporator coil in the rear area of the freezer behind a panel for being iced over,if so defrost it with a hand held hair dryer,then check the defrost heater element for continuity under the coil,if this is o.k. then suspect a defective defrost control
Jul 10, 2010 | Frigidaire FRS26H7 26 Cu. Ft. Side By Side...
The freezer isn't defrosting, and as a result the ice is building up inside it, and the temperature isn't as low as it should be.
I do not really do that much on the viking brands but you are having a defrost problem which is typical in all refrigerators. The problem will be 1 of 3 things. 1st defrost timer, 2nd defrost t-stat which is located on the coils in the freezer section behind the freezer wall and 3rd the defrost heater. Sorry I couldn't be of more assistance but 1 of these is your problem For temp fix so you have your cooling back you could remove the back wall of the freezer and using a hair drier deice the unit down so air can flow properly again. Good luck. Rick
Feb 24, 2010 | Viking 42 in Built In Professional...
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kolpak SK8-818-CI Logo
112 people viewed this question
Top Kolpak Refrigerators Experts
jasbo
jasbo
Marat Brikov
Are you a Kolpak Refrigerator Expert? Answer questions, earn points and help others
