Question about HP DesignJet 110 Plus NR InkJet Printer
Blocked lines
My black ink line seem to be blocked i tried almost everything recommended it seems i have to take the ink belt out to have it cleaned - any suggestions, thanks
    Novelist:
  • HP Expert
  • 175 Answers
Occasionally on the 1x0 range there is a valve stem issue that cause air to be allowed into the ink tube system and aslo for the ink to start crystalizing causing blockage , unfortunatly the fix includes a full set of ink tubes and possibly new printheads to complete the calibration
Posted on Feb 12, 2014
  • 3 Answers
SOURCE: Streaks / Bands of broken print area
No cleaning was successful, finally replaced the printhead and solved the problem.
Posted on Mar 06, 2008
  • 81 Answers
SOURCE: lines across printed page
try to locate the print head of the unit. you will see a mirror there. clean the mirror maybe it has some foreign object.
Posted on Jul 21, 2008
  • 27 Answers
SOURCE: Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Posted on Mar 05, 2009
smt24
  • 54 Answers
SOURCE: black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Posted on Jun 01, 2009
SOURCE: black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Posted on Jun 11, 2009
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
73N black is not printing
did you already replace the black cartridge? seems like a case of a blocked black cartridge. brother ink cartridges
Nov 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I get a blank line across all sentences when using black ink in either print or copy mode. I cleaned the cartridge while a little bit better it is still there. thanks
Wipe the underside of the cartridge with a soft tissue and then try cleaning the cartridge again, several times if need be. Blocked jets seem to be the problem here
Jan 28, 2011 | HP Officejet J5780 All-In-One InkJet...
Not getting clear print , parts of lines faint or missed, hard to read copies, seems to be bottom half of line,every 4th line
ink low, dodgy ink, or head is wearing, blocked and cant get enough ink to paper, try with manufactures ink, but more than likly the head is block no easy fix, normally a write off, once in a blue moon after much effort one can clean the print head, total sttrip down and windex or metho the print head once removed but be prepaired to work on it for 1/2 a day, get covered in ink, with a good chance of getting nowhere...I'd try fresh ink then I'd quote you more than its cost..labour intesive..sorry
Nov 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Black ink problem with printout on hp7780
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black ink failure
The ink is dried up in the cartridge.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
HP DesignJet 110 Plus NR InkJet Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
