Question about HP Pavilion dv4000 Notebook
Location of the CMOS battery in a HP Pavilion g series laptop. Is it on the bottom or under the keyboard?
    Top Expert:
  • HP Master
  • 26,644 Answers
4 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: HP Pavilion CMOS battery location
Hi!Checkout the image..Its circled in red thats where you will find it..As for getting apart refer you manual..It is just unscrewing and pulling out to remove the plastic cover..
Posted on Oct 19, 2007
  • 38 Answers
SOURCE: HP PAVILION ZV6000 LAPTOP CMOS BATTERY LOCATION
You have to take the keyboard off. Gently pry the plastic strip that is between the top of the keyboard and hinges. Unscrew the (2 to 4) screws holding the keyboard down. Slide the keyboard up and out. You should see the battery with 2 wires going to the motherboard. Pull the battery connector off the board, take out the battery and wait for about 30 seconds. Replacing it is easy once you have it open.
Posted on Mar 24, 2009
  • 64 Answers
SOURCE: HP Compaq nx9020 laptop cmos battery location on mainboard
On the motherboard,does the battery,that looks like a large capacitor.Have a serial number on it that can be matched to Compaqs operations/repair manual(s).?
Posted on Feb 15, 2010
Need to locate cmos jumper hp compaq8510p laptop
Its the little watch battery on the bottom of the laptop under the cover.
Jan 14, 2014 | HP Pavilion dv4000 Notebook
How can i restore my compaq cq70 laptop bback to its original settings,no password
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip.
So by cutting off the battery power, the BIOS/CMOS settings will be erased. cmos battery Under the keyboard or bottom of laptop -
If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Hope this helps
Mar 19, 2012 | HEWLETT-PACKARD Hewlett Packard 578999-001...
Required a password for my loptop what do i do?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps
Jul 23, 2011 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
How do I find out what the passcode is for my computer?
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased:.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps:
Jul 04, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Acer aspire 5515 cmos battery location?
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps!
May 22, 2011 | Acer Computers & Internet
I would like to find the location of my CMOS battery on my laptop HP Compaq nc6000 to replace the battery.
Try taking off the Keyboard, it is probably under there. There might be some screws on the bottom or snaps on the top.
Jun 12, 2009 | HP Compaq nc6000 Notebook
Mar 24, 2009 | HP Pavilion dv4000 Notebook
CMOS
The cmos on the Pavilion is going to be in one of three places, and will be one of two styles of battery. The cmos style will be either a large watch type battery about the size of a nickle located in a slot on the mother board, or in a yellow or greenish pouch with two wires leading to a connector, located under a cover on the bottom of the machine, or under the keyboard.
Aug 28, 2008 | Computers & Internet
Oct 19, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
