Question about Building Materials
The "One Button Close" feature will no longer work on my garage door opener. I have tried to reset it per the manual but it still will not work. Everything else works correctly.
Sears craftsman model 139.53985DM
4 Suggested Answers
  • 5 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 4348 Answers
SOURCE: Our Craftsman Model 139.53800SRT Keyless
Did you change the batteries?
Posted on Apr 23, 2011
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Aparker@primelending.comRe. the security+ light feature on LiftMaster #1265......it is no longer working. Light can be turned on, and comes on when door operated, but will not come on when beam is broken....
Try these instructions in case they are different from what you have.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Jul 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Skylink 318k remote garage door opener doesn't open door. Beeps according to the manual as it has always done but backlight no longer works. Is that the problem? Is only option to replace?
as far as the backlight, dont worry about it. You need the find the program button on the opener itself. With the door up, push the hard wired button,, on the opener, and the remote pointed to the opener, button at the same time to close. This should reset the remote..
Mar 13, 2011 | Garden
Keypad on garage door will only close if i punch in my code it won't close by hitting the enter button the temp here is minus 40 does that effect the keypad chamberlain 3/4 belt drive
Try this procedure to reactivate this feature.
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Won't Open or Close with Motor
you give nothing to work with. How old is unit. what brand? off track=no. way to reset -maybe OLD units have reset button on back panel (35 yr old_. Did you overheat by trying too many times. Wait 15 minutes for motor to cool and it will be ok. If none of this, provide more info (PS - is power on)
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
From the manual:
Security+Light Feature: Lights will also turn on when someone walks through the open garage door. With a Premium Control Console, this feature may be turned off as follows: With the opener lights off, press and hold the light button for 10 seconds, until the light goes on and off again. To restore this feature, start with the opener lights on, then press and hold the light button for 10 seconds until the light goes off, then on again.
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
29 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
