Question about HP Pavilion dv4000 Notebook
Location of the CMOS battery in a HP Pavilion g series notebook computer, is it under the keyboard on on the hard drive side of the motherboard?
    Top Expert:
  • HP Master
  • 26,708 Answers
This may help.
https://www.youtube.com/watch?v=UaH4GLDHgms
Posted on Nov 20, 2013
eagle338
  • 4889 Answers
SOURCE: HP Pavilion CMOS battery location
Hi!Checkout the image..Its circled in red thats where you will find it..As for getting apart refer you manual..It is just unscrewing and pulling out to remove the plastic cover..
Posted on Oct 19, 2007
  • 84 Answers
SOURCE: HP Pavilion dv4000 cmos battery
Here is the manual for your model
Hope this helps you
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Posted on Oct 23, 2007
EngineerGR
  • 119 Answers
SOURCE: HP Pavilion zv6000 Notebook PC keyboard replaced
Probably the keyboard you got is defective. I have seen buttons working in very bad conditions. When a key doesnt work or several is bad news.
Try to get a replacement. Since you have already reseated this simply check if the flex cable is properly locked, (ear plugs or similar) and not moving.
Posted on Mar 27, 2008
micromend
  • 748 Answers
SOURCE: CD DVD drive won't read application disks like Photoshop, Vegas
Either they put in a bad mother board or damaged yor DVD drive. Maybe they even put in the wrong unit. In any case I'd send it back to them.
Posted on Mar 22, 2009
  • 38 Answers
SOURCE: HP PAVILION ZV6000 LAPTOP CMOS BATTERY LOCATION
You have to take the keyboard off. Gently pry the plastic strip that is between the top of the keyboard and hinges. Unscrew the (2 to 4) screws holding the keyboard down. Slide the keyboard up and out. You should see the battery with 2 wires going to the motherboard. Pull the battery connector off the board, take out the battery and wait for about 30 seconds. Replacing it is easy once you have it open.
Posted on Mar 24, 2009
Required a password for my loptop what do i do?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps
Jul 23, 2011 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
How do I find out what the passcode is for my computer?
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased:.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps:
Jul 04, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
Nov 01, 2009 | Acer TravelMate 240 Notebook
How do I remove the hard drive from my HP N5495 pavilion laptop?
There is a basic rule of thumb with a notebook study the markings first then make determination of the task at hand..... I f there is not a screw on bottom of notebook that has a symbol of like cd's stacked which is the lock screw for the hard drive and it also should have a slidelock with it some do some dont. Check your system by examination of the workings and placement DVD players are so big then a hard drive could not be in a location like that. If you are going in get used to whats what and where it goes. If not then the hard drive is under the keyboard...Which the keyboard symbol will be next to the screws on bottom that correspond to this and there is usually slide locks on upperpart of keyboard top side also a flex cable underneath that is for the keyboard to function so if you are ready and can remember which hole each screw came out of each hole.........GOFORIT..........
Oct 14, 2009 | HP Pavilion N5495 Notebook
Where is the cmos battery located on HP Pavilion xh216 Notebook?
nooo its on the motherboard inside u have to take it apart why do you need to locate is. If you get a error message when you turn on the computer you just have to go to the drivers of the brand of your computer and download the bios driver
Jun 06, 2009 | HP Pavilion Notebook PC PC Notebook
Mar 24, 2009 | HP Pavilion dv4000 Notebook
Just wondering
For the HP Pavillion DV2000 series specifically : turn laptop upside down, remove battery , with small phllips screwdriver remove Hard drive access lid , you will see a small compartment next to the hard drive with a small button cell covered in black plastic wraping and a black and red cables plugged to the main board, unplugged those and wait 10 to 15 secs, plugged back, install battery and start the laptop you will a warning that bios settings had been restored to default, press F1 to continue and done.
Nov 27, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Cosmos battery
is it cmos? You will find the motherboard under the keyboard..usually there will be just two screws on each side that you have to unscrew to raise the keyboard...It will look something like this..its circled in red..just pull it upwards and insert the new one be careful about the signs make sure you align + with + and - with -a8f07e1.jpg
Nov 25, 2007 | HP Pavilion ze4300 Notebook
HP Pavilion dv4000 Notebook Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
