Question about Leviton Dhc Dimmer - HXC1D-1TW - Alabaster
HXC1D-1TW not working
How to determine if it's the dimmer or module that's failed? Also, can a failed module put voltage on the nuetral leg?
  • 2,113 Answers
The module if failed is either open circuit or short circuit. Being that it is a semiconductor you can test each leg for one or the other. If you had the numbers written on the component we could have checked a cross reference book for the type of semiconductor. It may be a mosfet (metal oxide semi-conductor field effect transistor). How to test a mosfet youtube video The rest of your dimmer is a variable resister or potentiometer or rheostat. You can test that for a failure with a multimeter in the ohms setting, though it is less likely to fail that the mosfet.
Posted on Nov 21, 2013
All power windows and moon roof stopped working on my 08 XL7 Luxury. When any window switch is pressed, all of the switch illumination lights go dim, then gradually get brighter. Took to shop, and they...
. The illumination is controlled by the BCM - body control module .
Interior Lamps Dimming
This group includes lamps which may dim. This group may use a combination of vacuum fluorescent (VF) illumination and incandescent lamps.
• HVAC control module, head assembly
• Rear HVAC control module, head assembly
• Radio
• Rear seat Audio
• The instrument panel cluster (IPC)
• The PRNDL lamp, with the exception of the current gear select position
• Power window switches
• Various switches
When the ignition switch is turned to the ON position, the VF display, radio, turns ON at maximum brightness. When the park lamps are ON, all incandescent back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. When the headlamp switch is placed in the PARK position, the park lamp supply voltage circuit provides an input to the body control module (BCM). The BCM then supplies voltage to the I/P dimmer switch through the I/P dimming lamps control circuit. The setting of the I/P dimmer switch determines the amount of voltage that the I/P dimmer switch supplies to the BCM through the I/P dimming lamps low reference circuit. The BCM then sends a pulse width modulation (PWM) voltage to all the interior lamps. All the VF and incandescent back lighting lamps are provided a specific voltage and are then grounded. When the headlight switch is turned to the park lamp or headlamp position, all incandescent back lighting turn ON at the dimming level indicated by the I/P dimmer switch. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Do you know what DTC'S - diagnostic trouble codes are ? Codes set in the BCM
DTC B2610 00: Passenger Compartment Dimming 1 Circuit
DTC B2615 00: Passenger Compartment Dimming 2 Circuit
DTC B2652 00: Passenger Compartment Dimming 3
Circuit/System Description
The instrument panel (I/P) lamp dimmer switch is used to increase and decrease the brightness of the interior backlighting components. The I/P dimmer switch provides a voltage signal that will increase as the brightness of the lights are increased and decrease as the brightness of the lights are decreased. The body control module (BCM) provides a low reference signal and a B+ voltage reference to the I/P dimmer switch. When the I/P dimmer switch is placed in the desired position, the dimmed voltage setting is applied from the I/P dimmer switch through the I/P dimmer switch signal circuit to the BCM. The BCM interprets the signal and applies the dimmed voltage to the I/P lamps supply voltage circuit and the interior backlighting components dim to the requested level. Ground for the I/P dimmer switch is provided at G201.
sunroof fuse 1 20amp / power windows - circuit breaker 25 amp
both of these are located in the instrument panel fuse box .
Mar 10, 2018 | Cars & Trucks
2005 cavalier dash lights not working. all fuses are goood. replaced cluster, dimmer switch, multifunction switch
Back lighting or warning lights ? check engine , ABS , air bags , seat belt , oil light etc... ?
The second group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination and incandescent lamps.
• HVAC control head assembly
• Radio
When the ignition switch is turned to the ON position, the vacuum fluorescent (VF) display (radio) turns on at maximum brightness. When the park lamps are ON all incandescent back lighting turn ON at the dimming level indicated by the IP dimmer switch. At the same time all vacuum fluorescent (VF) displays dim to match the indicated dimming level. When the headlamp switch is placed in the PARK position, the park lamp supply voltage circuit provides an input to the body control module (BCM). The BCM then supplies voltage to the instrument panel dimmer switch through the instrument panel dimming lamps control circuit. The setting of the instrument panel dimmer switch determines the amount of voltage that the instrument panel dimmer switch supplies to the BCM through the instrument panel dimming lamps low reference circuit. The BCM then sends a pulse width modulated (PWM) voltage to all the interior lamps. All the vacuum florescent (VF) and incandescent back lighting lamps are provided a specific voltage and are then grounded. When the headlight switch is turned to the PARK or HEADLAMP position, all incandescent back lighting turn on at the dimming level indicated by the IP dimmer switch. When the IP dimmer switch is moved from MIN to MAX, all vacuum fluorescent (VF) displays, as well as all incandescent back lighting respond from Minimum intensity to maximum brightness in response to the IP dimmer switch.
I would have it checked for DTC'S - diagnostic trouble codes stored in the BCM !
DTC B2624 Display Dimming Input Range/Performance
The body control module (BCM) supplies voltage to the instrument panel dimmer switch through the instrument panel dimmer switch signal circuit. The dimmer switch varies the voltage and returns the new voltage to the BCM through the dimmer switch signal return circuit. The BCM uses this voltage to determine the illumination level of the instrument panel lamps.
DTC B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit Range/Performance
The body control module (BCM) receives a variable voltage from the instrument panel (I/P) lamp dimmer switch. The BCM uses this signal in order to vary the illumination level of the I/P lamps. The I/P dimming lamps output from the BCM is a pulse width modulated voltage supply used to light the I/P lamps. If a malfunction occurs in the I/P dimming lamps output circuit, this DTC is set.
DTC B2662 Park Lamp Switch Circuit Malfunction
The park lamps are controlled by the turn/headlamp switch. Positive battery voltage is supplied to the switch through the EXT LP fuse. When the turn/headlamp switch is placed in the park or head position, battery voltage is supplied to the park lamps. The body control module (BCM) is also connected to the park lamp circuit to sense whether or not the park lamps turn ON when the low beam or high beam headlamps are turned ON. The BCM also uses the parklamp battery positive voltage to power the instrument panel (I/P) dimmer output circuit. If the BCM senses that the low beam or high beam headlamps are ON and the park lamp input is not active, DTC B2662 sets.
Do the park lamps work ?
Jun 11, 2017 | Cars & Trucks
Can I reuse a Lutron Maestro MAW-603 dimmer in a 2 way situation?
you should be able to by hooking up the black wire on the dimmer to the hot wire(that comes from the electrical panel) in the wall box and the red wire from dimmer to the switch leg(the wire that goes to light fixture). if the dimmer has a white wire(nuetral wire) you will need to hook that up to the white wires in the wall box....CAUTION!!! when removing the old 1 pole switch, there should only be 2 wires and possibly a green or bare copper ground wire attached to it. if either of the 2 wires(not the ground) are white, IT IS MISLABLED OR MISCOLORED. DO NOT hook the dimmers white wire to it cuz it will fry the dimmer. If this is the case, then most likley you do not have a nuetral in the wall box but look anyway for a couple of white wires tied together with a wire nut and stuffed in the back of the box. if you find those than most likely thats your neutral(check with a wiggy or meter to be sure) and thats where the dimmers white wire goes. hook up the dimmers green wire to a green or bare copper wire in the wall box and then put a wire nut on the dimmers red w/white stripe wire.
Feb 16, 2014 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
I have a 2004 Saturn Ion 2. I have several random problems with the car. First the Coolant light always come on when I first start the car, there is coolant in with no leaks. The Coolant warning does not...
Could have connection issues at the BCM - body control module , lose ground . The BCM controls all the thing's your have problems with .
Turn Signal Lamps
When the turn signal switch is place in either the right or left turn position, the turn/hazard request circuit is pulled low, through a resistor. The body control module (BCM) uses the resistors to determine if the left or right turn signals have been requested. The BCM then supplies an ON-OFF voltage to the turn signal lamps and turn signal indicator on the selected side of the vehicle. The turn signals receive a ground at G101, G401, or G403.
Engine Coolant Indicator(s)
LOW COOLANT LEVEL
The IPC illuminates the low coolant warning indicator when any of the following occur:
• The BCM detects a low coolant level condition for at least 30 seconds. The IPC receives a class 2 message from the BCM requesting illumination.
• The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds .
The thing to do first would be to hook up a factory or professional type scan tool an check for Instrument cluster or BCM DTC'S - diagnostic trouble codes . Then checking connection 's at the BCM , testing power an grounds .
ECM Inputs and Outputs Diagnosis
Open Circuit Detection Wiring Diagram 1
Mar 28, 2017 | 2003 Saturn ION
I have a hot and neutral to work with. From a switch I want trun a 2 outlet and a switch with outlet in one box with the 3 outlets hot all the time and the switch able to control the ceiling fan. Please...
Don, you need a nuetral at the fan and the other wire from the fan to the switch is the "switch leg" The switch leg goes on one side of the switch and the hot will pigtail to the other side of the switch and the outlets. The nuetral has to go to the fan and the outlets, thus hot outlets and a switch for the fan.
Jan 08, 2011 | Cooper Wiring Devices Combination Switch &...
Instrument panel lights do not come on.
Soldering the new bulbs in may have done something to the LH DIMMER MODULE ! The 10amp INT LPS fuse located in the I/P fuse box is good ? Is the dimmer switch at full bright ?
When the park lamps are on, battery positive voltage (B+) is supplied through the instrument panel (IP) fuse block INT LPS fuse via CKT 32 (YEL) to the dimming switch. The dimming switch supplies a variably controlled voltage to the dimmer module(s). The potentiometer in the panel dimming control cannot provide enough current in order to operate the panel lamps. The dimmer module(s) amplifies the current, supplying the variable voltage to the panel lights. As the amount of the current increases, the lamps become brighter. As the amount of the current decreases, the lamps become dimmer.
Buick
There is only 1 dimmer module that supplies current to the panel lights. The left dimmer module supplies current via CKT 8 (GRY) to the following components:
• The headlamp switch
• The door switch flood lamps
• The heater and A/C control
• The door handle flood lamps
• The passenger temperature control
• The ashtray lamp
• The shift select switch lamp
• The instrument cluster
• The steering wheel controls
• The reset switch
• The trip odometer
• The radio
Parade Dimming
The parade dimming feature prevents the dimming of the VF displays when daylight is sensed by the lamp control module (LCM) and the park lamps are turned on manually. If the LCM senses night time conditions and the park lamps are on, the LCM allows the VF displays to be dimmed.
All of the modules with the VF displays receive the dimming level from an input on CKT 8 (GRY) or CKT 1244 (BRN). When the LCM determines that the above conditions are met, the LCM sends a signal to the instrument cluster and the radio via CKT 390 (YEL). For Buick, the radio then relays this information to the heater and A/C programmer and passenger temperature control via CKT 724 (PPL/WHT). The modules with the VF displays then adjust the dimming level of their VF displays to match the level of the incandescent lights.
LH Dimmer Module
Under the left side of the IP, on the left side of the steering column brace
May 25, 2017 | 1998 Buick Riviera
Don't know how to find code
You should have a tech number to Leviton on your instalation instruction.
May 09, 2009 | Electrical Supplies
TAYLOR 632-33 ICE CREAM MAKER
If you are wiring a Taylor machine to three phase power and you have a "wild leg" or "high leg" you must place the high voltage leg on L3. This will keep the higher voltage out of the control circuits of the machine. To clarify what a high leg is, it is created in three phase applications where a certain type of transformer is used. It creates two normal power legs, 110-120 and one leg that is only useful with another leg of power. If measured to nuetral or ground a wild leg will measure considerebly higher than the other legs. Hope this is helpful
Aug 06, 2008 | Taylor 632-33 Ice Cream Maker
What size fuse (and where are they located)are needed to fix the following non lit accesories on a 2003 Buick Le Sabre ltd? -Steering Wheel accesories - Climate Control, Volume - Radio controls. -Climate...
Are all of these not working ?
• Air temperature switch
• Cigar lighter lamp
• Door switches
• Driver information center (DIC) switch
• Headlamp switch
• Head-up display (HUD) switch
• Heated seat switches
• HVAC control assembly
• Instrument panel cluster (IPC)
• Memory function switch
• Radio
• Steering wheel controls
• Window switches
This group of interior lighting includes lamps which may be dimmed. This group uses a combination of class 2 controlled illumination and incandescent lamps:
• Door switches
• Headlamp switch
• Radio
• Window switches
For the interior lighting to be dimmed the following conditions must be met:
Here is a discription of how they work ,factory service info.
• A low light level has been detected by the dash integration module (DIM)
• Headlamp switch is placed in to the PARK or HEAD position
• Ignition switch is placed in the ON position
Then all class 2 displays and all incandescent back lighting will be illuminated to the level set by the instrument panel (I/P) dimmer switch. When the I/P dimmer switch is moved from MIN to MAX, all class 2 displays and all incandescent back lighting respond from minimum intensity to maximum brightness.
The DIM supplies battery positive voltage to the coil side of the PRK LP relay in the rear fuse block.
When the I/P dimmer switch is moved from MIN to MAX, then the instrument panel module (IPM), W/CJ2, or climate control panel (CCP), W/C67, applies a message to the class 2 communication circuit to the DIM. The DIM then applies a ground to the park lamp relay control circuit. This energizes the PRK LAMP relay and allows battery positive voltage to be applied through the DIMR fuse to the DIM. The DIM then illuminates the following incandescent lamps through the incandescent dimming output circuit:
• DIC Switch
• Headlamp switch
• HUD switch
• IPC
• Radio
The DIM also applies a message to the following class 2 controlled illumination components:
• Drivers door module (DDM)
• IPC
• Radio
The DDM will then send a message through the simple bus interface (SBI) to the RH front door module (RFDM). The door modules will then illuminate the following components through the incandescent dimming output circuit:
• Heated seat switches (W/KA1)
• Memory function switch (W/A45)
• Power door lock switches
The ground for these components are provided from the DDM and RFDM.
The following components are grounded at G200:
• Headlamp switch
• Radio
The following components are grounded at G201:
• DIC Switch
• HUD switch
Having the vehicle checked for DTC'S - diagnostic trouble code's would probably be your best course of action .
DTC B2556 (1)
The I/P dimmer switch is a potentiometer. The instrument panel module (IPM) determines the control setting based on the voltage from the I/P dimmer switch. The IPM sends out a class 2 message to the dash integration module (DIM). The intensity of the interior backlighting shall be adjustable when ever the park lamps are on. The intensity of the vacuum florescent displays shall only be adjustable when it is night and the park lamps are active.
DTC B2627
DTC B2628
Circuit Description
The I/P dimmer switch is a potentiometer. It is powered by the HVAC control module. The HVAC control module determines the level of dimming desired based on the voltage from the I/P dimmer switch. The HVAC control module converts the I/P dimmer switch feed back voltage to a digital signal and puts it on the Class II communication bus.
Dash Integration Module (DIM)
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Control of headlights and exterior lamps
• Horn relay control
• Interior lamps incandescent dimming
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules
Your best bet ,take your vehicle to a qualified repair shop.
Nov 20, 2017 | Buick LeSabre Cars & Trucks
Leviton Dhc Dimmer - HXC1D-1TW - Alabaster Logo
111 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
