KENMORE WASHER #1102781269 OVERFLOWING - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Replace the water level switch located in the console. Just remove the back plate to gain access to it. Here is the part to order.
Posted on Nov 21, 2013
My Kenmore He Model 11028002012 backs-up intermittently. Not every wash but if I wash two loads back-to-back the drain overflows.
The drain overflows? If it is coming up out of the standpipe that the washer drain hose is hooked into, its not a washer issue, it is a clogged/slow house-hold drain issue. I suggest a plumber in that case.
Sep 17, 2017 | Kenmore Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Kenmore washer model 1102781269 over fills
Possible that the settings of the water level sensor is too high, you need to short the switch and see if the inlet flow stops. if not there are issues with the main controller unit.
Check this links for tips: controller unit
Nov 20, 2013 | Washing Machines
Kenmore 70 series washer over fills
there is a plastic tube that runs
from the tub to the overflow switch in washer. If this develops a hole in it, air
pressure is not applied to the switch to shut it off. good-day !
Dec 17, 2011 | Kenmore Washing Machines
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Kenmore 80 Series top loader washer overflows
It will not be a sensor,,,it will be what is called a "Ball **** valve" and they are pretty cheap to replace.
This same valve is in your toilet tank.
Jan 19, 2009 | Kenmore 22422 Top Load Washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite HE 3T front load washer
Hope this helps ...... F09 is a Overflow Condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check/ Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation PLEASE rate my solution
Oct 04, 2007 | Kenmore 44832 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
