Question about Maytag Neptune MAH5500B Front Load Washer
Door locked will not run - Maytag Neptune MAH5500B Front Load Washer
  • 38 Answers
  1. If it does not fill it will be a upper control board . Does it feel your touch if not the touchpad is shorted ,this sends pulse to control board .
Posted on Nov 21, 2013
2005 Chevy Impala. The door locks keep locking during drive.
It's probably a bad input to the BCM - body control module ! Have it checked for DTC'S - diagnostic trouble codes .
The automatic door lock function can only be enabled by the body control module (BCM) if the driver door open switch and door ajar switches are in the Closed state. For information on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
DTC B3064 or B3069
DTC B3127
DTC B3128, B3133, or B3138
DTC B3132
DTC B3137
DTC B3272
Your best bet , take it to the chevy dealer . Unless you own a GM factory Tech 2 scan tool an have access to factory sevice repair info.
The outputs to the door lock actuators are controlled by the body control module (BCM). When the BCM receives a lock input from a door lock switch, or a keyless entry transmitter, it applies battery positive voltage to the door lock actuator lock control circuit, a ground to the door lock actuator unlock control, and the driver door lock actuator unlock control circuits. When the BCM receives an unlock input from a door lock switch, it applies battery positive voltage to the door lock actuator unlock control, the driver door lock actuator unlock control circuits, and a ground to the door lock actuator lock control circuit . When the BCM receives an single Unlock input from a keyless entry transmitter, it applies battery positive voltage to the driver door lock actuator unlock control circuit and a ground to the door lock actuator lock control circuit to unlock the driver door. A second Unlock input from the transmitter applies battery positive voltage to the door lock actuator unlock control circuit, and a ground to the door lock actuator lock control circuit to unlock the passenger doors.
This diagnostic procedure supports the following DTCs:
• DTC B3128 Left Front/Driver Door Unlock Circuit High
• DTC B3133 All Door Unlock Circuit High
• DTC B3138 All Door Lock Circuit High
Jul 21, 2017 | Cars & Trucks
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
DE code, machine will not run. door working properly
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Aug 06, 2011 | LG WM2042 Front Load Washer
The door locks when the start button is pressed, but the cycle will not start. Diagnostics shows F26 door lock assembly. Whirlpool WFW8300SW. I have replaced the CCU and it still locks but nothing happens...
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 18, 2010 | Whirlpool WFW8300SW
The door locks activate after the car is off and doors are locked
not completely sure. but im am pretty sure your door switch is bad. unplug your door switch and see if the doors stop trying to unlock
Jan 06, 2010 | 1996 Pontiac Grand Am
Says FL and won't run
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Main control board.
If the wire harness is ok, replace the door lock mech.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Locked via keyless with engine running
Most newer cars have a safety feature that locks the door when the ignition is turned on or the car is put in gear. This can sometimes be a problem, as you found out, if the keys are left in the ignition in the on position and you get out of the car shutting the door sometimes this safety feature kicks in and locks the door on you with the keys in the car. I understand this was a mistake on your part, thinking you did take the keys, but if you ever just stop with the car running and jump out to run in the house, roll down the window enough to get your arm in to unlock the door.
May 29, 2009 | 2009 Nissan Versa
Electronic door locks self operate when ignition is off.
take out the fuse in the fuse box! owners manual will show you where
Dec 12, 2008 | 1994 Nissan Quest
We have a 2007 Entourage and you cannot lock it with the car running. We installed a remote starter and it will not lock the doors when it is remotely started. Can this feature be disabled?
i think that this is to prevent you from locking your keys in the car with the engine running.
Some remote starters have a feature that when the car is running (and in park) you can hit the remote start button twice for one second each - then you can take the key out of the ignition and still have the car running.
At this point....if you would hit the 'lock' button on your door the doors would immediately unlock. However, if you get out of the car and close the door leaving it unlocked and then you hit the 'lock' on your original car remote the doors will lock and stay locked. So now the car is running the doors are locked and you have the keys in your hands. Then you can run into the store or house real quick with your car locked.
Once you come back, you hit 'unlock' on the original car remote. the doors will unlock - you can get it - and then before hitting the brake put the key in the ignition and turn it (dont crank it) as if you had when originally using the remote starter.
Maybe this will work for you.....
Oct 14, 2008 | 2007 Hyundai Entourage Limited Minivan
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
