Question about Jet 3 Ultra Power Chair
Chair wont turn on
I plug my chair in and the amp meter on the side bounces once and nothing is coming on it worked fine day before yesterday i checked the fuse and hit the reset can you help me
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 168 Answers
Sounds like the power is not getting through, check the batteries are they charged? if not there is prob a loose lead or battery needs to be re fitted to be sure they are making proper contact.
Posted on Dec 02, 2013
3 Suggested Answers
  • 692 Answers
SOURCE: when i plug my chair in using the onboard charger,
Then you must have a charger problem. If you have a digital voltmeter or access to one. Set it to 200 volts dc and plug the leads into the two outter holes of the charger port located under the front of the joystick. Without the charger plugged in you will be reading the current voltage of the batteries. Now plug the charger cord into the wall socket and the reading on the meter should go up to 26-30 volts. if it doesn't change the reading after a few minutes then the charger is bad. Now you can get an off-board charger for your chair somewhat cheaper than an on-board charger. If you have a friend or neighbor that has a chair or scooter with an off-board charger you can borrow it for a few hours to charge your chair until you can get a charger of your own. Check on e-bay for any good 4 amp charger for a power chair it would work fine to charge your chair. Hope this helps you
Posted on Oct 20, 2010
  • 692 Answers
SOURCE: Chair was working fine. Then
Evonne the batteries were probably overcharged you should never leave it charging for more that 12 hours Check that the freewheel levers are in the drive postion they are two levers under the front of the seat. They should be pointing toward the center of the chair. If they are in the drive mode then there are other problems. Contact Roadrunner Mobility @ 1-800-467-2668 to see if they have a tech that can come out to check the chair Medicare will pay for most of the repair cost if they paid for the chair. Hope this helps
Posted on Mar 01, 2011
Electrical Issue
sounds like just the key switch has failed.
Check the connector, and make sure no pins have pushed out of either side of the connector.
Apr 03, 2014 | Harley Davidson XL Sportster 883...
1988 Ford f250 460 starts and runs fine sometimes it wont' start
check the alternator maybe less power delivery from it
Apr 12, 2017 | 1988 Ford F 250
I have a htt 9c chair. it was working yesterday. I went to use it today and it would not turn on. it has no power and circuit is fine. please help
First, check the power with a volt meter on the receptacle you are plugged into. (or plug a lamp into the receptacle and make sure it turns on. believe it or notI have seen this many times) If power is fine, then remove the back of the chair (with the cord unplugged) and stabilize the back of the chair as the wires hang from the back of the chair to the chair itself. Plug back in your chair and check power to the on/off switch on the back of the chair, if you have power there then it gets a little more complicated. Again, unplug the chair, remove the black plastic cover on the lower left of the chair that covers the main circuit board. You should see a soldered in fuse, use an ohm meter and check the fuse for continuity. If it reads good or "shorted" then you are past my knowledge in this matter. Hope I could be of some assistance.
Jun 28, 2011 | Interactive Health New Htt 9c Curve Track...
When I plug in my Jet 3 Ultra 4500, it seems to charge - the charging lights come on - but it never charges. In fact, I can't get it to move at all, even when plugged in. I think I am using the...
when you plug in the charger do you get any amp reading on the meter located at the rear of the chair near where the charger cord plugs into the chair. When you plug in the cord the meter should deflect and read 6 amps or so. If you aren't getting any deflection of the amp meter then either the batteries are dead or the charger is bad. If you have a voltmeter you can set it to 200 volts dc and plug the leads into the charger port located under the front of the joystick Plug the leads into the 2 outter holes of the port with the charger plugged into the wall you should be reading 27-30 volts. Unplug the charger and you will be reading the battery voltage and fully charged they should read 25-27+ volts. If you aren't reading 25-27 volts without the charger plugged in you will need new batteries( anything less than 10 volts will not let the chair turn on) if you aren't getting 27-30 volts with the charger plugged in then the charger is bad and you can get or borrow an off-board charger and charge the chair thru the joystick port Hope this helps
May 07, 2011 | Jet 3 Ultra Power Chair
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
How do I know if my jet 3 ultra is charging? I just bought a used one today and do not have a manual
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
Feb 02, 2011 | Jet 3 Ultra Power Chair
When i plug my chair in using the onboard charger, my meter will not move, I have juice going into the charger but nothing comes out.
Oct 19, 2010 | Jet 3 Ultra Power Chair
91 Geo tracker , Starting problems
my geo tracker wont turn over the lights wont come on nothing is working iv tested the battrey its fine and checked all the fueses they are fine too why is there no power to any thing?
May 31, 2010 | 1991 Geo Tracker
My LG decided not to come on the day i went on holiday, i mean no power no lights nothing, come back try again, nothing so i go and buy a new 38'' LG tv, tried the old one once again, comes on fine put it...
It is not you tv its the plug on theb wall. It is probably loose, and causing the intermittent problem you are having. You may notice looseness as you plug it into the wall. Your TV is fine.
Aug 09, 2009 | LG 32LC7DC 32 in. LCD HDTV
Chair fully charged lrd lights flashing and chair wont move
Try using a Voltage meter to test the Voltage coming from your batteries. Your batteries should be as close to 12v. your motors are 24v. Even if just one battery is bad this can cause alot of headaches.
Jun 20, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jet 3 Ultra Power Chair Logo
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
