Question about Gaggenau 28 in. CK 171 Electric Cooktop
I have a GAGGENAU MODEL CK 596-615, the power button is flashing red doen't allow me to perform any operation
I need the two front knobs that come out from the front lower inside unit that are the igniter controls for tge gaggenau vg 353 112 cd. Please lead me to the part numbers and a parts supplier. Thanks brian
Here are the diagrams, parts list, and sales of the parts. Specific to Gaggenau VG353. Additional site to order parts: Essentials For Your Home website, just put in the part number from the diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232110&diagram_id=193996#d193996
Jan 16, 2011 | Gaggenau 15 in. VG 353 Gas Cooktop
The cooktop has locked me out, there is a red key that comes up when I push the power button, how do I unlock it?
I'm fairly certain all you need to do is press down where the illuminated red key is for about 5 seconds. If this doesn't work, please let me know and I will check on the correct method for this exact model.
Regards,
BElectric
Dec 13, 2010 | Gaggenau 28 in. CK 171 Electric Cooktop
The cooktop will not turn on. The little red light in the lower right corner of the touch panel is blinking. If one touches and holds it it does not turn on a burner per usual. The timer function works....
I'm going to assume this is a new installation, either way, it sounds as if you're only getting one leg of your 220v circuit, which wld run the timer and lights but not enough to power the burners. This is prly not something you shld try and repair yourself as a 220v circuit can cause some serious damage. At the least, you could first, TURN OFF THE BREAKER and then check the connections to the cooktop to make sure all connections are secure.
Jun 11, 2010 | Gaggenau CK 171 28 in. Electric Cooktop
How do you light gas manually when power is out?
Turn your burner on to high, then use a lighter with the long spout on it to light the flame by moving the lighted flame to towrds the burner slowly.
Make sure to use the type of lighter that allows you to stay back so you do not get burnt.
If the burner does not light do not let it on for more than half a minute.
Heatman101
Jan 21, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Wont turn on, LED just blinking
Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
Gggenau offered a rep at 400-500 eur for this ! Shame on them !
S:DOlberg
Jan 15, 2009 | Gaggenau 28 in. CK 171 Electric Cooktop
Ck596-615
hi im gerbee,very complicated the all the elec stove coz very sensetive the sensor,try to remove the ceramic glass,check all the screw at the side of cooktop before removing the glass then clean it the pcv control sensor using an alcohol,& clean the clean also under the glass, dust & oily surface coz of the poblem of the sensor.
Nov 30, 2008 | Gaggenau 47 in. CK 596 Electric Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Replacement dual burner Gaggenau CK594
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Jan 15, 2008 | Gaggenau 47 in. CK 594 Electric Cooktop
Gaggenau VG-352-812 Cook top
You should be able to go online to Gaggenau and in the service area there is a link for order parts
Jan 03, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau 28 in. CK 171 Electric Cooktop Logo
61 people viewed this question
Top Gaggenau Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
