Question about Qualstar TLS 8433 (TLS-8433) Ultrium Tape Drive
User manual I can't clear this error message. Handler Fault Not Clear Code 35-1706-1103 Enter to Continue
    Top Expert:
  • Qualstar Master
  • 6,702 Answers
Because the TLS 8433 can be assembled out of different drives (LTO /Ultrium and so on) and can be used with different operating systems, I only could get some links to qualstar.
Perhaps when looking here, toy can find your way to the correct configuration and error.
3 links
Posted on Nov 27, 2013
Need to clear system alarm #112
This is a Fujitsu LifeBook S6240 NoteBook
The user manual s here http://solutions.us.fujitsu.com/www/.../S6240_05SUM_USERSGUIDE.PDF
I cannot find error 112 in it.
However
*Press <F1> to resume, <F2> to SETUP
Displayed after any recoverable error message. Press
the [F1] key to continue the boot process or the [F2]
key to enter Setup and change any settings, this will allow you bypass the error.
Ttttt
Sep 25, 2014 | Intel S6240 Notebook
Code 35-1706-1103 in Qualstar TSL 8433
Sorry, just saw this one.
You are addling the tape robot with what software? can you tell?
Nov 20, 2013 | Qualstar TLS 4222 AIT Tape Drive
Code 35-1706-1103
In what configuration are you using this drive(s) Can you tell me more about the drive unit, like type number, installed drives and so in?
Nov 20, 2013 | Qualstar Computers & Internet
I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
It's an error code that will not go away until a technician resets it. Quote straight from the manual :
"The oven may detect a fault during programming or during operation. If a fault is
detected, the message "Fault detected - press power to clear" or "Fault detected -
press enter to try again" may appear. Follow directions in the display. If the fault
reappears or does not clear, call an authorized servicer or the toll-free number in the
display.
If the same operation is attempted before having the wall oven repaired, the message
"Feature not available" will appear. The feature will remain inoperable until service
is obtained":
Mar 15, 2011 | Jenn-Air 30 in. Pro-Style Electric Single...
System error 000 and 003
The E000 and 003, are the code for temperature fault in fixing unit.
There are two possibilities...
First:
enter service mode *(add.function) 2 8 *, by keys left/right go to CLEAR and OK, select ERR and OK.Turn off and on.
If these helps, you can continue to copy.
Second:
if the error clear not working you need to replace fixing heater.
Hope that helps!
Feb 11, 2011 | Canon iR 2016i Black and White Copier
1999 BMW 323i Message reads "Code Wait" after I
Your going to need to reset the codes in order to clear this issue.
Please remove the main red lead going into your BMW battery, wait a few seconds, then reinstall the lead. The error code will now go away. If you continue to have problems, please return.
Jan 19, 2011 | BMW 3-SERIES CONVERTIBLE
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Xerox Workcentre Pro 215
This should resolve that fault code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Qualstar TLS 8433 (TLS-8433) Ultrium Tape Drive Logo
134 people viewed this question
Top Qualstar Computers & Internet Experts
David Payne
David Payne
Are you a Qualstar Computer and Internet Expert? Answer questions, earn points and help others
