Question about GE Washing Machines
Frigidaire model ltf2140fs motor control - GE Washing Machines
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
My Frigidaire brand refrigerator blower motor does not come on. Where is it located in this refrigerator?
Your evaporator fan is located in the back section of the freezer. In this particular model the fan is energized by the ADC(auto defrost Control) which is in the control panel in the fresh food section. Behind the thermostats. The red wire with a white tracer is the power feed to the fan from this control. The condenser fan is beside the compressor in the back of the unit.
Mar 03, 2015 | Frigidaire Refrigerators
How do I repair my front load washer that seems like the water pump will not allow the water to drain?
did you check the water filter on the lower part of the machine to be sure it isn't stopped up?
Sep 25, 2014 | Frigidaire Washing Machines
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Model:22S750 machine will wash wont spin dry clothes
Its usually a door lock problem, motor control board, or drain pump issue on front load models. if its a top loader model its probably your lid switch.
Sep 05, 2012 | Frigidaire Washing Machines
Washer doesn't spin.
Try the motor controller, if you bought the unit before 2006 the part should have a 5 year warranty, check your manual. If not in Warranty the part is 178.99 average. The motor controller is in the back right corner of the machine. If you have a ohm meter check the motor for correct ohm readings, easy to do. The tech sheet inside the machine ( left side behind kick panel in a brown envelope) has the test procedure and ohm readings.
Jul 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
27 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
