Question about Frigidaire Washing Machines
Frigidaire top load washer does not spin until I depress the lid lock switch
Runs OK in wash and rinse cycles. Will not start spin cycle unless I open the door and depress the connection to the door switch .
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Is the strike still in place on the lid? What is the model number?
Posted on Nov 21, 2013
Testimonial: "Yes, the strike is in place. I have to move the arm under the lid much further than the strike would to get the spin cycle to start. Model is FEX831S2, Washer Dryer Combo"
5 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: top load Ge washer model number WVSR1060A1ww will
There can be many reasons and i will do the best to cover everything that can happen with your washer to cause it from not draining or spinning. I will attempt to cover the basic things that can happen with washing machines.
First thing to check if your washer is not pumping or spinning is to see if the motor is running. If themotor is not runningb>then check the lid switch. When the lid gets slammed it hammers that switch and eventually will bend it or break it completely. Some washers will wash but not spin or pump, others will do nothing. This switch is located under the lid on the edge of the frame around the lid. Often there is a hole that a pin from the lid will go through and push on a lever that is the switch. Check that it is not simply bent, so that it does not trip the switch inside anymore. To change or check the switch the top will need to be raised or the front removed. Getting to it, is often harder then the replacement.
Thank You, Mike Here is also My personal Sight to Help with other problems you might have as well.
Posted on Oct 03, 2011
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
jumptrout51
  • 3361 Answers
SOURCE: washer will not spin
Your neutral drain is not locking in.
Let the timer advance to the final spin cycle. Once there it should have about a 5 second pause and the transmission spin gears will lock in. If no pause replace the timer. If you have the pause and still no spin replace the transmission.
My bet is on the timer.
Posted on Apr 01, 2009
  • 6 Answers
SOURCE: Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Posted on Nov 18, 2009
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Problem with spin in rinse cycle
Yeah that is a lid switch problem. I have a page I compiled that shows how to fix this easily: HERE
Jan 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Frigidaire Wash Machine
It may be it the Lid switch... bad lids swithes will stop washers from going into the spin and pump out cycle...
Sep 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
