Hotpoint f5 machine is block
I connot open the machine, the machine is displaying f5, machine is block
  • Washing Mach... Master
  • 17,130 Answers
Possible fault with the controller unit
Check this link for tips to probe: controller unit
Posted on Nov 21, 2013
3 Suggested Answers
  • 30 Answers
SOURCE: F5 BEING DISPLAYED
check pump or pressure switch
Posted on Jun 09, 2009
57 varieties
  • 1653 Answers
SOURCE: Hotpoint washine machine ERROR F5 machine blocked
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood. Alternatively bale out the sump under the main screen filter plate.
  3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked or restricted.
  4. Also check that the main waste drain pipe and one way valve to a sink waste connection if you use one, is not blocked and clean if required.
  5. Access the pump from under the lower rotor arm and protective grille and check that the impeller is free to move and is not clogged or restricted by debris or sludge. Clean as required.
  6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power. It is a good idea to take digital pictures of the pump assembly before attempting to work on it or remove it so that you can refer back to it when you reassemble the unit or replace it with a new unit at a later date / time.
8. Remove and check the electrical connections to the pump and make sure they are in good order.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage. If they are then clean them thoroughly.
10. Then remove the pump and check motor is OK and that the motor turns OK. Also check that the pump impeller vanes are in good order and not blocked. If necessary replace the pump with a new and identical unit.
11. Carefully reassemble the pump observing the correct placement of gaskets, seals, O Rings, hoses and securing straps, electrical wiring.
12. Reconnect the hoses and then reconnect power and switch the machine on.
Also see additional info to follow.
Posted on Nov 14, 2009
What does f5 mean
F05 - Pressure switch jammed on full* consult with repair tech.
this is for the EV01 model.
Jul 29, 2014 | Hotpoint Washing Machines
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine keeps flashing F5... It works for the cycle but when it starts to get to the spinning process it flashes F5 and doesn't work
Sounds like a blocked pump, unfortunately unless you are very handy they make it impossible for you to do it as it involves leaning the machine back and taking off hoses etc and it can be tricky to get back on unless as I say you are a DIY'er.
Sep 05, 2011 | Hotpoint Washing Machines
Hotpoint aquarius stopped working full of washing F5 showing on screen
hi im pretty sure f5 is pump blockage try filter on the front bottom right hand corner behind the kick plate if its not blocked it could be the level switch this is located under the lid its a round switch with a plastic tube going into it this could be faulty thankyou
Jan 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Says F5 on display, wont empty.
just had F5 blockage warning on hotpoint aqualtis. Removed front panel on the bottom and unscrewed filter, cleaned and replaced. checked all outlet pipe was clear. Laid washing machine on to its back and removed black pipe from pump and checked and finally removed the other end of the pipe that joins to the drum. large ball acts a valve and a missing sock was found in the drum end! replaced all parts and washing machine works a treat! before the f5 warning the machine leaked from the door on a couple of occasions, no problem since and may have been a build up of water finding its only way out.
Jul 12, 2010 | Hotpoint Washing Machines
F5 BEING DISPLAYED
Jun 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint AQGD169S flashing F5 machine blocked
mine said the same ive cleaned it out but when i took the back off ive noticed rusty coloured water comeing out of the back of the drum do you no what this may be as its not turning now
Apr 23, 2009 | Hotpoint Aquarius WD640 Front Load...
Cannot open door
f5 means a blockage. you will need to drain it by putting the drain hose lower than the machine to syphon it out into a basin. then you can check the filter for the cause.
Jan 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
