Benq W600 I replaced DMD chip to fix white pixels, this has worked I now have a flawless image but I get 'no signal' message so I cannot play anything. I have tried HDMI 1 and 2 and PC serial but I still get 'no signal' message.
  • Martin Belcher Nov 21, 2013
    I figured it out, I thought I must have damaged the motherboard by bending it during initial removal. I could not see any signs of stress or cracks so I went around each chip and large component and squeezed them on both sides of the motherboard to make sure none had popped off even slightly. I reassembled the projector and it works perfectly again. I reckon one of the chips had lifted of the board slightly.
    What a relief. After taking it apart half a dozen times I was almost ready to quit, very happy I can play xbox again now.
    Champion:
  • 213 Answers
Check you cables from your dmd make shour you plug all the cables in to your dmd bord sound like you not plug the single cable from tuner bord to the dmd.
Posted on Nov 20, 2013
    Thank you. Good idea but the HDMI and PC inputs are actually integrated to the motherboard itself.
Clean light engine
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Jan 16, 2014 | BenQ (200NSH-LAMP) Projector Lamp for...
Suddenly, benq mx511 has white pixels showing up....multiplying every day...now the projected image consists of 50% snow.
It probably has the same DLP chip as my Mitsubishi television. The mirrors in the chip set get stuck and create the white spots. There is no way to fix this other than replacing the DLP chip.
Feb 04, 2013 | BenQ MX511 3D Projector
I have a benq MP670 that i bought i China 3 months ago and i live in Kenya... it has white spot al over the place... but there are many in the right side of the screen... what can i do?
Sounds like the DMD chip is getting bad pixel failure. Most likely the chip will have to be replaced.
If the white spots are well defined and rectangular in shape when you get up close to the screen, then this would confirm the problem.
Just tell your friends that it's snowing in Kenya and the snow flakes are getting on the screen and ask the children to try and brush them off. Make the most of it until you can get it fixed, or get another broken one that has a good dmd chip and swap parts.
Sep 20, 2011 | BenQ MP670 3D DLP Projector
Dots appearing on the display screen
if these are pixel shaped dots then the DMD chip is most likely faulty
Apr 11, 2011 | BenQ MP622 DLP Projector XGA 2000:1...
The projector has several white dots on the screen. how can i fix it, it started with a few white dots then every time i used it, it doubles and doubles until it became many dots.
I have the same problem. I think we need a class action!
http://s1231.photobucket.com/upload/albums/m3231/?location=projector+spots
Oct 06, 2010 | BenQ MP511 Projector
White pixels forming on screen and increasing in number. Slight distortion in other spots pixels are extremely bright but small.
This is a problem with the internal DMD chip which needs to be replaced.
Contact BenQ Service,should be covered under warranty.
Samir
Aug 22, 2010 | BenQ MP523 DLP Projector
White dots on screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screen. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 27, 2010 | Samsung HLS4266 TV
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on bottom.top of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Feb 09, 2010 | Samsung HLR5064W DLP Projection TV
Rca 61 inch dlp has vertical lines accross the screen , they come and go by themselves
Hi,If you are experimenting vertical lines ,color distortion,pixilation,or white dots on the screen you might be having an issue with the Dmd chip.This is how the DMD chip works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip is composed of around 2 million pixels that create the image on the screen.You will need to replace in order to fix your problem.Have a blessed one!
Feb 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
