Question about Craftsman Sears Liftmaster Garage Door Opener Safety Beam Sensor Kit 41a5034
Craftsman garage door opener does not work everytime. can someone give me some tech support?
Garage door opener model #139.53993 dm will not work everytime. i changed to a different source of electricity and that made no difference. after it did not work or light up i banged it with my hand and the lights came on and when i pushed the button the door opened. when i pushed the button with the lights still on it went down. when i waited for the lights to go off it would not work again until i banged it with my hand again. it seems to me that maybe there is a bad relay or something. i took the cover off and there is 120 volts to the connections ok.
5 Suggested Answers
swolfinor
  • 504 Answers
SOURCE: Sears 41A4315-7E garage door opener trouble codes.
4 FLASHES TELLS YOU THAT THE PROBLEM IS WITH THE SAFETY EYES.
THEY MAY BE OUT OF ALIGNMENT OR HAVE A DIRTY LENS.
BE SURE THE EYES ARE CLEAN, MOUNTED SOLDILY AND AIMED CAREFULLY.
THE LEDS SHOULD BE LIT BRIGHT AND STEADY (NO FLASHING OR FLICKER)
NOTE: IF SAFETY EYES ARE MOUNTED TO THE TRACK THEY MAY MOVE OUT OF ADJUSTMENT AS THE DOOR GOES UP AND DOWN. - ADJUST TRACK
HOPE THIS HELPS
Posted on Dec 01, 2010
swolfinor
  • 504 Answers
SOURCE: I have a craftsman garage door opener and recently
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Posted on Dec 16, 2010
  • 11 Answers
SOURCE: I need to replace my
Google "61LM". You will find it or its equivalent for sale on the internet.
Posted on Jul 26, 2011
8880u81
  • 3103 Answers
SOURCE: garage door opener
recheck the door to see if you got it "off center" if it drags at all the motor will not open it..once it glideds up and down freely run the motor to full open..then reatatch the door connector to it while opened.. cycle to see if it will go up and down..
Posted on Jan 07, 2014
I have Craftsman garage door opener model 139.53675SRT2.I have two remotes which all of a sudden will not work. Wall pad works, and keypad works. What gives?
1. Check batteries in the remotes.
2. Someone may have reprogrammed the opener without realizing it. Look at the instructions for the unit and follow directions on matching the remotes to the opener. This may involve setting some tiny DIP switches in the opener and the remotes.
Nov 06, 2014 | Building Materials
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Coding garage door opener
Refer this problem to Sears for resolution
Jun 07, 2013 | managemylife.com
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
The garage door opener inside the garage doesn't open or close the garage door. How do I diagnose? The model # is: 41A5389-1B
The model number you give is a part number for the logic board. Does your remotes work? Is it only the wall control that isn't working?
Sep 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener model 139.53985 DM opens only about 2 feet then stops then closes when the button is pressed again; will open when I put pressure on the door and continue that pressure all the way up.
On the rear of the motor unit near where all those white wires go you will find the 'up force' control. Increase this a bit and try. Make sure you don't have a broken door spring.
Nov 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am looking manual for Craftsman Garage Door Opener 315 Model No. 139.18191. Thankful if you can help me in finding it. Thanks and good luck. Prem Anand
That doesn't seem to be a good model number for Sears. Double check it and then you can call 800-528-5236 which is Sears tech support for garage door openers. They should be able to help you. Or if you are having a problem you can post that and we will help.
Nov 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I code the garage door wireless key pad?
simple ;find the smart button on the opener and pressit ,their will be an indicater light next to the smart button that will remain lit ,then go over to the keypad and put your 4 digit code in example1234 then press enter on keypad and hold down for 3 seconds until garage door opener lightbulbs shut down and come back on , and thats it simple as pie! when the lights go on and off on your machine it,s telling you that it has received the code that you just programmed into it , guaranteed to work everytime , Thank you for letting me help you Sincerely Glenn mayer
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
From the manual:
Security+Light Feature: Lights will also turn on when someone walks through the open garage door. With a Premium Control Console, this feature may be turned off as follows: With the opener lights off, press and hold the light button for 10 seconds, until the light goes on and off again. To restore this feature, start with the opener lights on, then press and hold the light button for 10 seconds until the light goes off, then on again.
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Sears Liftmaster Garage Door Opener Safety Beam Sensor Kit 41a5034 Logo
63 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
