Question about 2002-2009 Chevrolet Trailblazer Headlight Bulb Sylvania - OE Replacement, Low Beam
How to change a headlight bulb on a 2002 trailblazer
    Sergeant:
    Champion:
  • 208 Answers
You need to take off the center grill. on each headlamp there are two tabs" one one eaither side of the assembley". that will will need to pull up. after words pull out the headlight assembley remove the wires that are conected to the light. the remove the large rubber dust cap then twist the bulb holder to remove the bulb from the assembley, WARNING (when installing new bulb do NOT toutch the bulb this will shorten the life of the bulb) install in reverse order
Posted on Nov 20, 2013
How do I change my headlight switch in a 2002 chevy trailblazer
try switching #45 and #46 fuses, the two big ones ,they match each other in size and shape, for some reason this will make your head light s work again.
Dec 24, 2014 | 2002 Chevrolet TrailBlazer
2002 trailblazer headlight
Try swapping relay #45 & 46 in the underhood fuse panel as a test. Relay #45 is for the low beams. Also check the headlight bulb connectors for signs of overheating.
Dec 14, 2012 | 2002 Chevrolet TrailBlazer
High beam headlights don't work, changed the bulbs, and checked the fuses, help
This is going to be a problem with your light switch or dimmer switch. Replace the light switch and see if that resolves the issue.
Nov 27, 2011 | 2002 Chevrolet TrailBlazer
How to change right front headlight
Drivers side? reach your hand by the alternator and over to the back of the headlight. You'll feel round rubber covers, pull this out and twist the bulb out.
Passengers side- take the aircleaner top off and move the air cleaner out of the way. Then you have a ton of room to change this bulb.
Jan 12, 2011 | 2002 Chevrolet TrailBlazer
Replacing headlights in my 2002 chevy trailblazer
You have to get to your headlights inside the hood. You turn your light bracket a quarter of a turn to unlock it. Then pull the bracket out, the bulb will be attached. Do NOT touch the new bulb with your bare hands. The oil from your skin will cause the halogen bulb to get tooo hot and will burn out. You might as well change both of the lights as well. The other one will be going out soon.
Jul 10, 2010 | 2002 Chevrolet TrailBlazer
How do you change a headlight on a 2002 chevy trailblazer
Your grille and chrome bar are held to your truck with eight clips. You can see the top clips if you look. First VERY GENTLY!!! start pulling your grille until you start popping those clips out. Keep an eye on your chrome bar, because it is clipped into the headlight. GENTLY pull on the chrome bar at the headlight until the clips come off, then work your way over to the other headlight. The goal is to be take your time and be gentle until you have all the clips released. Set your grille aside(be careful not to scratch it). Each head light has two metal tabs on top of it, the outer tabs are slightly hidden in the fender. If you pull these tabs up, it will release the headlight from the frame of the truck(be careful not to let the headlight fall out and scratch your bumper). Once you have the headlight assembly out, pop off the circle rubber cover on the back of the unit. Your bulbs will be inside there, and make sure you don't touch the bulb when removing it. Just reverse the process when your done changing your bulbs. Don't forget to put the rubber cap back on the headlamp unit before you re-install it.
Jun 25, 2010 | 2002 Chevrolet TrailBlazer
How to install headlamp on a 2002 chevy trailblazer
To change a headlight bulb in the 2002 Trailblazer: I writing this with the orientation of standing in front of and facing the Trailblazer.
Open the hood.
Remove the plastic cover that goes from the left to right over the headlight bracket, radiator, etc. It has 4 plastic pop retainers and 2 sheet metal screws. Remove the grill center bar that passes in front of both headlights. The grill and center bar come off as one piece. Start at one end and carefully pry it out, a little at a time. There are 2 clips at the headlight and 2 clips near the center top of the grill and 2 at the bottom. Two more in the other headlight.
Each headlight has 2 black metal clips that hold the assembly onto the bracket. One is above and behind headlight assembly, towards the right end if you're working on the left headlight (and visa-versa), and the other is under the fender (it pulls up OK, but may take some patience to push it back down when you're done).
Pull the entire headlight assembly forward. I only moved mine an inch or two. On the back of the assembly are round rubber covers. Pull off the one covering the back end of the bulb that needs changing. reach in and turn to bulb clockwise 1/4 turn and it will slip out.
Unhook the connector from the bulb. It has a little catch on it, otherwise it just pulls out.
Connect the new bulb.
Reassemble everything in reverse order.
As I said, the under fender clip that holds the headlight assembly on to the bracket may take some patience. It seemed to slip down OK once I had it in exactly the right position. Either that I needed to reach the required amount of cussing.
Good Luck...
Oct 24, 2009 | 2002 Chevrolet TrailBlazer
How do I change the headlight on my 04 Trailblazer?
Hello;
Can't show you exactly, but is easy to take the grill out and change lamps while it is out! Grill has clips, you just have to un-clip it, pull two tabs on each side on the top and the whole thing comes out! (20 Minutes)
57ChevyGuy
May 02, 2009 | 2002 Chevrolet TrailBlazer
Need to know how to remove cover to replace lamp in headlight for 2002 chevy trailblazer
you dont remove the front cover, open the hood look behind the headlight and turn the bulb couter clockwise, and replace the bulb in the headlight.. good luck keith...
Mar 21, 2009 | 2002 Chevrolet TrailBlazer
2002-2009 Chevrolet Trailblazer Headlight Bulb Sylvania - OE Replacement, Low Beam Logo
88 people viewed this question
Top Sylvania Headlight Bulb Vehicle Parts & Accessories Experts
Darrell
eric allen
eric allen
JonSnell Electronic
JonSnell Electronic
Are you a Sylvania Headlight Bulb Vehicle Part and Accessory Expert? Answer questions, earn points and help others
