Question about Mitsubishi WD65737 65" DLP TV
Hdmi inop all 3 inputs
Component video works ok.
  • 52 Answers
First thing to check is that you actually have a source signal FROM the HDMI output. Second thing to check is the cable. The audio is embedded into the signal path, so if you don't receive picture, then you shouldn't receive audio.
Check the above on a neighbours set etc, before then having to check TV settings. Finally, do a factory restore on the TV set, via the menu driven software.
Posted on Nov 26, 2013
Testimonial: "HDMI source works fine on the other DLP set in the home. Did factory reset (Menu-1-2-3), and this cleared all input sources. Connected HDMI source and TV recognized it and asked for label. Selected proper label and input is active, but no audio nor video. Read error code log, found only codes for prior lamp failure at 8900 hours. Suspect main board has a failed IC."
  • Gary Miller
    Gary Miller Nov 26, 2013
    Found free download of service manual athttp://www.eserviceinfo.com/downloadsm/6... Full schematics, and service adjustment procedures.
Slinteriors
  • 8617 Answers
SOURCE: WD-62525 horizontal lines in picture when using component inputs
code 12 means the set isnt experiencing any shutdown symptons. I would check for more capacitors in the same circuit where you found the other often they show no visible sign of deterioration. If you need a service manual to figure out which capacitors are in that same circuit you can get the manbual for your set for 10.99 at the following link. They will even email it to you if you go back to the site and let them know you want it emailed. heres the link hope it helps.
http://servicemanuals.vstore.ca/
Posted on Jan 20, 2008
jerryg50
  • 1689 Answers
SOURCE: Help!
It is possible that the HDMI ports are blown. The work through their own circuit area in the TV set. This is a particularly complex area.
You will have to send the set to the authorized service rep for an estimate. See if your home insurance plan will cover for this type of thing. Some types of home policies will cover for this type of thing. The cost of servicing your set may be expensive. Damage from a lightning strike will not normaly be covered by warranty.
Jerry G.
Posted on Jun 13, 2008
SOURCE: Mitsubishi HDTV model wd-62525 has
It has been renamed.
Posted on Mar 22, 2009
gymhasafit
  • 31 Answers
SOURCE: Single HDMI Input. Need to connect several HDMI components
Number 1 would be to connect the 3 Devices to a Receiver with 3 HDMI Inputs, So this way you get the HDMI Audio as well. 3 in and 1 out to the TV as you know. The other way would be to get a Key Digital HDMI 3 to 1 Switcher. I have used these a lot in the field on installs and they work Great. They also have 4 to 1 if you think you might need more. No programming of the piece you just plug in and setup your TV in the HDMI Menu and your other Devices. If they don't sync AUTO! The Receiver would be Best I feel, Some let you assign 2 different Video and Audio sources at once. Such as Video from a Game and Audio from a CD. Hope this helps out!
Posted on May 05, 2009
gopakumarg43
  • 75283 Answers
SOURCE: I have a wd-62525 dlp i have pic and sound through
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Posted on Oct 10, 2011
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
I needed to know how do connectd my dvd player with my tv and ditail cablebox form coxs
HI,
IN THREE WAYS
1. FROM DVD'S OR CABLE BOX'S HDMI OUT PUT TO ANY OF TVS HDMI IN PUT VIA HDMI CABLE ( FOR THIS BOTH SHOULD HAVE HDMI CONNECTIVITY )
2 DVD'S OR CABLE BOX'S COMPONENT VIDEO OUT TO TVS COMPONENT VIDEO INPUT VIA COMPONENT VIDEO CABLE ( NORMALLY COMES IN THREE COLOUR ). ALSO CONNECT AUDIO USING A TWO RCA CABLE.
3 . AND ALSO THROUGH COMPOSITE VIDEO CONNECTION.
SELECTION FOR THE TWO DEPENDS ON U. ACCORDING TO UR REQUIREMENT.
OK
Dec 13, 2010 | Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Apr 20, 2009 | Mitsubishi WD-73833 73" HDTV
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
May 05, 2008 | Onkyo TX-SR605 Receiver
Mitsubishi WD65737 65" DLP TV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
