Question about Whirlpool Dryers
Mdl geq9800lgo How do I access the thermal fuse? The back doesn't seem to come off.
    Sergeant:
    Champion:
  • 310 Answers
Pull the top off and you will see the srews for the back
Posted on Nov 21, 2013
2 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: wont start How do i access the thermal fuse?
HI if theres a bottom panel on you dryer. remove front panel. their is where the thermal fuse is located on the air duct. if you dont have a bottom panel. pull the dryer from wall. remove back panel. clean all dust in dryer and the venting. the thermal fuse is on the left, on the air duct. a small plastic piece, with 2 blue wires to it. replace this part. thanks the appliance doc.please rate my answer. thanks.
Posted on Oct 11, 2008
No heat gas dryer
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardless)
May 29, 2012 | Maytag Dryers
Whilpool gas dryer mod. AGD4475TQ2 No heat
May 28, 2012 | Whirlpool Dryers
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
Whirlpool gas dryer will not get hot
May 22, 2012 | Dryers
Gas dryer not heating up
May 21, 2012 | Kenmore Dryers
Dryer does not get hot
May 02, 2012 | Kenmore Dryers
Kitchenaid gas dryer model # kgys750jq does not heat up
Sep 26, 2011 | KitchenAid KGYS750LQ Gas Dryer
Dryer tumbles, but does not heat
Sep 20, 2011 | KitchenAid KGYS700LQ Gas Dryer
Our Whirlpool dryer model #LER7646AQ0 will not start. Door switch checks for power with a power tester. Put new start switch in and still doesn't work. Do I need to use Ohm tester or will power tester...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Jan 11, 2011 | Dryers
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
