Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
I go directly to the point. My duet washing machine stuck on C05 when at test mode. Check Amp at the heater = 7.9 Amp. 120 Volt at the heater, heater ohm at 15 Ohm, NTC sensor test at 5,6 K Ohm with water in the tub, NTC test 10 K ohm at room temp. Took the NTC Outdoor in cold temp. and show 13 K Ohm. Clean the NTC... But still the machine refused to go on with the test mode. Check the continuity of NTC wires to the CCU Ok. Check heater wire continuity ok
  • Whirlpool Master
  • 17,129 Answers
You might get some tips from looking through this video which explains some of the related issues
click on : control panel problems
Posted on Nov 21, 2013
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
aborcass
  • 2651 Answers
SOURCE: F 06 whirlpool duet washer
mcu is responsible for the f06 fault code
Posted on Mar 24, 2008
AlmostBob
  • 550 Answers
SOURCE: Whirlpool Duet washing machine - no cold water
Check the tap is turned on
if not fix
turn off taps, check the lint screen inside the hose end (tap connector end) is not blocked
if not fix
check cable connections on cold water solenoid valve inside rear of case
if not fix
replace cold water solenoid.
cold water solenoid valve fails more often than hot, is used on every cycle so bnurns out first.
unplug washer and turn off water before checking cables or replacing solenoid.
solenoid is cheap, common to many washers local parts guy will have one that fits even if it is labelled ge frigidaire kenmore
Posted on Sep 22, 2008
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
  • 4088 Answers
SOURCE: duet ghw9100 washer clunking noise on spinning
With the machine off, push upward on the inner drum and release. If the clunking sound occurs and the drum seems somewhat loose, likely the front main bearing for the drum is damaged and must be replaced. Major tear-down!
Posted on Nov 28, 2009
Kenmore Elite HE4T washing machine diagnostic test not completing - getting stuck on C05
http://www.managemylife.com/images/6975/original/346.jpg?1303498921
According to this it could be either the Computer (don't think so but don't rule it out just yet.), the fill valve, or the heater. Appliance Repair Forums
This link will help you test the fill valves.
This will link you to a service manual for the HE3T washer which is very similar to yours and the diagnostics and tests will be the same. https://www.ifixit.com/Document/1074/.pdf
Jan 20, 2017 | Kenmore Washing Machines
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Thanks/Mike
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Why is Whirlpool Duet washer stuck on add a garment
is the door lock light on?if not the lock switch may be bad, or the board may not be sending power to the switch.a volt-ohm meter must be used to test the system.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer door will not lock. Get a DLF default code
If you remove the kickplate thats located in the front lower part of the machine you will find a tech sheet in there with directions on how to activate the diagnostic mode and have the machines cpu run test on all the parts and tell you what the problem is
May 18, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fi pops up on my front load whirpool duet model wfw9200sqoo. and wont finish the cycle. unless we manualyput in rense and spin mode and somtimes unplug it, and reset spin mode,, and somtimes like today...
Frontload failure code
F-1= EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU. Bummer.
DUET SERVICE MANUAL AND MORE HERE
Jan 25, 2011 | Whirlpool Washing Machines
Control lock light is on and cannot get the washer to do anything
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in theOFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
?Close the door.
?PushCONTROL/ON(if present on this model).
?Select theDRAIN/SPINcycle.
?SelectNO SPINby pressing theSPIN SPEEDtouch-pad.
?PushPREWASH OPTIONfour times within five seconds. (If
PREWASH OPTIONis not present on this model, pressEXTRA
RINSEfour times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push thePAUSE/CANCELtouch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTIONtouch-pad two times. IfPREWASH OPTIONis not
present on this model, pressEXTRA RINSEtwo times.
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet front load washer door locked & will not cont wash cycle
you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
Nov 11, 2009 | Whirlpool Washing Machines
Won't complete wash cycle, stuck at wash after time end!
check heater or thermostat,check is it heat water
if not heat water then heater or thermostat is broken.if you have ohm meter you can check both
,unscrew behind sheet metal and find heater disconnect one wire from it and check it(meter must show some value e.g.30 ohm).
Jul 05, 2009 | Washing Machines
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
