Question about Hoisting
Cogs are misalined - Hoisting
Shift stiff
Switch connected to gear shifter not adjusted or misalined.
May 09, 2017 | Cars & Trucks
Gaggia titanium inside cog won't line up with brew units cog, the brew units is in the correct possision. Machine comes on some one said I need a new ct board
If you've had the back off it may be this.....there are two grey plastic prongs sticking out of the back of the casing, when you've put it back on they haven't gone into the two lugs that are on the back of the cog, this affects the two cogs lining up.you may have to pull the cog up a little to line them up when you put the back on, the cogs should line up again as long as the prongs have gone into the lugs. Hope this this helps.
Oct 17, 2015 | Gaggia Titanium Espresso Machine
Hyundai code P0016
That code is for a crankshaft and camshaft misalinement.The timing belt could have jumped a tooth out of alinement.
Oct 30, 2012 | 2006 Hyundai Santa Fe
My rca screen turned green then shut off
open up and check for a dry joint at variable settings on chronos to screen controller if all cables ok ( check for pin damage on connector first sometimes a misalined pin prob
Feb 21, 2012 | Proton MM2701VT 27" TV
Microwave will not turn off.
it sounds like a mikro switch is misalined.
Dec 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 1999 Lincoln navigator that has a vibration when shifting during moderate to hard acceleration. It sounds and feels like I am running over "rumble" strips on the side of the road.
take an oil sample and check for cutting if any is found then you may have some worn or broken components llike bushings or bearings causing misalinement
Jul 22, 2009 | 1999 Lincoln Navigator
HORN HAS STOPPED WORKING, CHECKED 10AMP FUSE AND IT LOOKS OK
take apart the horn assembly after you remove the fuse see if it is broken or just dosent look right might be misalined for an especially bad day in traffic
also check all the other fuses might be labeled wrong
Nov 29, 2008 | Toyota Yaris Cars & Trucks
AEG LAVAMAT 74620 Update Gears on the fill tray have jumped. The primary and idler have to be installed correctly and are fool proof but the third, half gear, needs setting. Can you please supply pic or...
Found this on another site (fixed4free.com) posted by Dave in Jan 2009:
This is one of those things where a picture would be worth a thousand words, but as I can't put pictures on this site, the words will have to do!
- Turn the orange cog anti-clockwise as far as it will go, (putting the nozzle to direct the water to the conditioner drawer)
- Look closely at the orange cog and you'll see that the last-but-one tooth at each end of the row is shorter than the rest. Looking from above and standing at the front of the machine, I call the rightmost tooth on this cog number 1, the short tooth number 2 etc. (my cog has 17 teeth)
- Position the white cog so that (looking from above) the leftmost tooth on the top (incomplete) row of this cog is between teeth 2 and 3 of the orange cog. This should be such that if the white cog rotates anti-clockwise it will turn the orange cog.
Now the difficult bit:
- The shaft that the yellow cog fits on has four vertical 'webs' running down it. Look closely and you'll see that one of these is bigger than the other three. As you would expect, if you look carefully at the centre of the yellow cog it has three small slots and one bigger one spaced around the hole.
- This shaft can be VERY CAREFULLY rotated if you pull it gently upwards against it's spring and wiggle it while twisting it. NEVER force it, the cogs underneath are VERY fragile. If it won't turn, just let go, and try again.
- Look again at the white cog, and you'll see that two of the teeth on the lower (complete) set of teeth have no slot between them, they make a tooth that is 'double width'.
- Look at the yellow cog and you'll see that it has a 'double width' slot on it's lower row.
- The challenge is to rotate the yellow cog's shaft so that you can fit the yellow cog on it, aligning the double-width slot on the yellow cog with the big tooth on the white cog. This is just a case of trial and error, but is the key to getting everything back together.
COMPLICATED BIT OF EXPLANATION!!
The yellow cog only ever turns clockwise and the white cog is a clever bit of engineering allowing AEG to move the nozzle (orange cog) backwards and forwards across the five positions.
The yellow cog turns the orange cog anti-clockwise until it runs out of teeth, then the white cog turns the orange cog the other way.
After a full rotation of the yellow cog, the orange one has moved clockwise to the stain-treatment position and the by-pass beyond, then anti-clockwise back to the conditioner position.
Apr 16, 2008 | AEG Washing Machines
Hoisting Logo
321 people viewed this question
Top Hoisting Experts
JAIJITH
John Kopischke
John Kopischke
Level 1 Expert
gbob59
Are you a Hoisting Expert? Answer questions, earn points and help others
