Question about Ricoh Aficio CL1000N Printer
Service code 385
What is a sc 385
  • 87 Answers
ID sensor adjustment error during process control self-check (this check happens when you switch on). Most likely cause is a dirty ID sensor, but there are other possible reasons. Start by cleaning the ID sensor and see how it goes from there.
Posted on Mar 28, 2014
Pro c900. What does error code sc544 mean?
SC 544
Heating roller thermopile (center) error 3 The thermopile detected a temperature over 260?C. • TRIAC short, AC drive board defective • Defective IOB 2 • Defective BCU sc_note_1.gif
Related SC code: SC 553, SC563 1. Do SP5810 to cancel the SC fusing code. 2. Replace the AC drive board. 3. Replace the IOB 2. 4. Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
Mar 13, 2016 | Ricoh Office Equipment & Supplies
Error code sc211
This error code SC 211 not exist.Exist SC 2-11 is the communication problem.For reset the SC codes following the procedure:enter in the service mode (press total clear key-1-0-7-Clear keyhold down more 3 sec.Enter SP 5-810 SC code reset and select `1`.Then hold down the original type key and the OK key at the same time.This does not require the main switch to be turned OFF and ON.
Aug 12, 2009 | Ricoh Aficio 2015 Copier
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Sc code 672 with aficio 2090
Direct from the service manual:
• Controller board defective
• Controller board installed incorrectly
• Operation panel harness connection loose or incorrect
May 03, 2009 | Office Equipment & Supplies
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
RICOH AFICIO AP3800C
This normally suggests to the transfer belt it is possibly worn and the transfer unit will need replacing
Hope to be some hep
Jan 02, 2008 | Ricoh Aficio AP3800C Laser Printer
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Ricoh Aficio CL1000N Printer Logo
89 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
