Question about Sony RDR-VX530 DVD Recorder/VCR
Got programble light on and cant get it back so i can use it
Cant adjust temperature
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
Nov 29, 2013 | GE CustomStyle PSC23NSTSS Stainless Steel...
Doors automatically lock sometimes while in motion other times after the engine has been shut off. Using the remote to unlock the doors results in the doors unlocking them immediately relocking.
it depend upon the program of the alarm system.the mitsubishi alarm system is programble or u can check the alarm system control under the steering column and check the central lock controller,the main actuator on the front driver side door
Feb 19, 2011 | 2005 Mitsubishi Galant
Cant change be back tail light
MORE THAN LIKELY THERE ARE MORE FASTENERS TO REMOVE WHEN YOU OPEN THE TAILGATE
Nov 29, 2009 | 2000 Ford Explorer
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
CANT GET FRONT LIGHT AND INDERCATORS WORKING BACK LIGHTS ALL WORK OK
check fuses and then retrace each indicator conector wire back to the fuse . Once this is done check the fuse to power line if it is a factory problem then they should be able to fix the problem directlly and frre of charge regardless if you brought the bike new or used it is there responsibilty.
May 06, 2009 | Factory bike Chrono SM 250 Motorcycles
1998 toyota 4 runner back hatch handle broken
get inside the back take door panel off mipulate door latch to open
Jan 14, 2009 | 1998 Toyota 4Runner
Philips car radio
how many connector plugs do you have on the back
Jul 22, 2008 | 1986 Renault Sport
How to my motorola gtx
Yes this radios is programmable, may be this radio works on 800Mhz with trunking protocol. you´ll need a RSS (Radio Service Software) to program it and a hardware as well.
Dec 01, 2007 | Radio Communications
Sony RDR-VX530 DVD Recorder/VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
