Question about Staples SPL770M Shredder
Jammed Staples shredder/ Heavy duty/ strip cut
4 Suggested Answers
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
pctech1
  • 1940 Answers
SOURCE: I need 1/4"staples for my Swingline Heavy Duty
http://www.staples.com/Swingline-Heavy-Duty-Staples-1-4/product_504225
Posted on Mar 09, 2011
  • 42042 Answers
SOURCE: I have a Staples SPL-TXC152A shredder. I need two gears: the big plastic one and the large metallic black one. Badly stripped!
if you can get them from the manufacturer spares , the cost may exceed a new unit
Posted on Jun 14, 2016
I need a power cord for the SPL-XC180P Staples Shredder. Where can I get one?
Amazon com Tripp Lite Heavy Duty Power Cord 15A 14AWG IEC 320 C19 to NEMA...
I think this cord would work for you. But the manual for this shredder might have a number you could call to for parts or questions. I think you have a Staples shredder. Not sure that calling Staples help desk would yield a part supply like this.
Aug 20, 2017 | Car Audio & Video
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
Jan 12, 2015 | Heavy Duty Stanley Bostich Heavy-duty...
My shredder jammed, I cleared the jam and now it will not start. I have hit the reset button and still no luck
Could be it also overheated / overloaded during this process both are quite common when people are impatient and feed them more than they can deal with or if they go beyond the duty cycle (somewhere in the instructions that you did not read it will say say duty cycle use for 5 minutes nonstop rest for 20 or something similar) In any case it sounds like an overload if you are lucky there will be an overload button hidden somewhere on the device sometimes it is even on the underside of the head press the overload button firmly till you hear it click and try again. If that does not work the internal fuse may be blown (factory only repair)
if this is the case get a newby with a capacity that exceeds your current and future requirements that way you cannot overload it
Jan 05, 2015 | Intimus S 407 Heavy Duty Strip Cut...
My heavy duty shredder purchased 3 months ago has quit. Some times if you slam it down on the bin it will come on. It acts like the sensor thinks the bin is full. It is not indicating or seems to be over...
Shredders also have sensors to detect when they are off the bin. A safety feature obviously.
I'd make sure the shredder is properly oriented and sitting firmly on the bin.
May 23, 2011 | Staples Office Equipment & Supplies
My stanley model tr 250 seems to be jammed up and won't load staples
Generic comment.
There should be a pin or a screw (probably with a locking nut) on the business end of this machine. Find it, remove it and the track should pull down allowing you to clear the jam.
I hope this helps
a
Sep 27, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
I have an achiever heavy-duty crosscut shredder that I purchased in 2002. Since that time I have actually used the shredder around 5 times. The shredder turns on, shred for about 2-3 mins., then it stops....
does it finish the sheet of paper then shut off , or does it stop halfway thru the paper?
unplug the unit , open it up and see if theres staples or junk jammed in the cutting wheels/gears
there supose to turn off once its finished with the paper and turn back on when the next paper is inserted , theres a lil sensor that turns it on and a limit switch that turns it off
Jul 11, 2009 | Achiever CCS5000 Shredder
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Staples SPL770M Shredder Logo
67 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
