Question about Windchaser Dryers
The fan will not turn with it is switch on. the motor just has a slight hum to it. the blade can turn free by hand, what what would you think might be the problem? it was working fine last week. please help.
    Genius:
  • Windchaser Master
  • 1,617 Answers
Check the capacitor to see if it's going bad. It's usually black with wires going into the pull chain switch.
Posted on Nov 21, 2013
4 Suggested Answers
night71
  • 328 Answers
SOURCE: Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Posted on Nov 18, 2007
dnewcombe1
  • 1564 Answers
SOURCE: Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Posted on Sep 07, 2009
Testimonial: "Unbelievably fast response - off to try to fix it!"
  • 12173 Answers
SOURCE: Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Posted on Sep 12, 2009
How do I check to see if the motor is bad on my ceiling fan?
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
Apr 28, 2016 | Hampton Bay Dryers
When the fan or A/C control is turn on a hum can be heard but nothing happens. I went up and the fan initially wouldn't turn. I got it to spin, but still only a hum when the switch is turned on. Seems...
With the unit off put a drop of 3 and 1 oil on the fan shaft where it goes in to the motor and spin the blade by hand a few times to work the oil in the motor. If the shaft is dirty in the area clean it first with alcohl on a rag to get the grime off it then oil the shaft.
Mar 20, 2011 | Heating & Cooling
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Fan won't run at all.
    If you plug it in and turn it on, does it "humm".
    If so, it is getting power. It could be the blades are stuck on something: do they turn by hand?
    The motor could be dirty also, is the blade hard to turn?
    It can be repaired by Vornado, or you can dis-assemble the motor and clean it.
    Dec 24, 2010 | Vornado Circulating Fan
    The fan blade doesn't turn. The motor hums, the blade turns freely when you pushit with your hand.
    possible bad capacitor.or motor windings are grounded.
    try replacing the capacitor first.
    Aug 18, 2010 | Heating & Cooling
    Sep 12, 2009 | Windchaser 3-way Oscillating Fan
    Blades will not turn
    The motor probally damaged while you are moving the fan to the new house.
    Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
    Hampton bay fan noise
    The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
    HOWEVER...
    The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
    * If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
    * If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
    * Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
    * Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
    I hope this helps you! If you have any other questions, or need clarification, please ask!
    Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
    Celing fan making noise, how to oil
    HOWEVER...
    Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
    Ceiling fan
    There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
    Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
    Dryers Logo
    120 people viewed this question
    Top Windchaser Dryers Experts
    john h
    Vernon Taylor
    Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
