Question about Vehicle Parts & Accessories
Zero start installation instructions
Inline coolant heater for cold start diesel
3 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: '06 3500 diesel, while driving the heater was
You need to check your vaccum pump and hoses
Posted on Oct 08, 2009
  • 474 Answers
SOURCE: Block Heater not working.
the element may be bad.take an ohm meter and put the leads to each prong.if no resistance check cord. if cord is good replace element
Posted on Dec 14, 2009
Glow plug location on a Boomer 30 yr 2013
two different heating units and are not to be confused
a glow plug is used to heat the compressed air in a diesel engine so that it ignites the atomized fuel easier and so it starts quicker
A block heater keeps the engine coolant from turning to ice in sub zero conditions and so stops the engine block and heads from cracking from the expanding ice
Jan 01, 2018 | Cars & Trucks
Can you put an engine block heater on a 2004 f-150 non-heritage model fx4
block heater mostly for diesel engines.living colder climates use 5W - 30 ENGINE OIL make sure you 50/50 coolant and water mixture or add little more coolant if you live in zero temperatures have strong good cold cranking AMP battery cold start ups should be no problem.add fuel treatment to fuel to keep out water.
Jul 28, 2013 | Vehicle Parts & Accessories
Renault Scenic 1.9TDI Diesel 2000 heater is blowing out only cold air
Hi Paul, check the engine coolant level, the thermostat and the valve operation which controls the coolant going into the cabin heater. The most likely problem would be with the heater regulator valve.You'll find that located on the fire wall between the engine and cabin. It will have two hoses and an adjustment device fitted. It very well may be stuck. Regards John
Oct 09, 2012 | Cars & Trucks
How to start 92 npr diesel in cold weather
You will probably need some Ether based starting fluid. You may have to remove air filter to shoot a 2 second blast into the intake - but first try shooting the air intake with the 2 second blast and start vehicle. Diesel fuel tends to thicken in cold weather and a fuel additive like Lowes diesel fuel treatment may help keep your fuel fluid in colder weather. In cold weather, like on a night of clear skies causing low temperatures, a block engine heater will help to keep your fuel fluid - along with the diesel treatment. Block heaters are not too difficult to install depending on your vehicles configuration and how much room you have at a freeze plug, and are well worth the cost.
Hope this helps and please rate my solution!!
Dec 17, 2010 | 1999 Isuzu VehiCROSS
How to remove heater core from buick cintury 1995
With Air Conditioning
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Disconnect the negative battery cable and drain the cooling system.
  2. Disconnect the heater hoses from the heater core inlet and outlet connections in the engine compartment.
  3. Allowing residual coolant from the heater core to drain. Cap the openings.
  4. Working inside the vehicle, remove the lower instrument panel sound insulator.
  5. Remove the heater floor outlet duct screws or clips and remove the duct.
Remove the heater floor outlet duct screws or clips ...
... then remove the heater floor outlet duct
6. Remove the heater core cover by removing the attaching screws and clips.
7. Remove the heater core cover.
8. Remove the heater core retainers and remove the heater core.
Remove the mounting bolts which retain the heater core
To install:
  1. Position the heater core in the housing and install the retaining straps.
  2. Position the heater core cover on the housing and install the attaching screws and clips.
  3. Install the floor outlet duct and attaching screws or clips.
Exploded view of the heater core and case assembly
  1. Install the lower instrument panel sound insulator.
  2. Working in the engine compartment, connect the heater core inlet and outlet hoses.
  3. Fill the cooling system.
  4. Start the engine and check for coolant leaks. Allow the engine to warm up sufficiently to confirm the proper operation of the heater.
  5. Recheck for leaks. Check the cooling system level.
  1. Drain the cooling system.
Heater and air conditioning module assembly
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. If equipped with a diesel engine, raise and support the car on jackstands.
  2. Disconnect the hoses at the core.
  3. On diesels, remove the instrument panel lower sound absorber.
    1. Remove the heater duct and lower side covers.
    2. Remove the lower heater outlet.
    3. Remove the two housing cover-to-air valve housing clips.
    4. Remove the housing cover.
    5. Remove the core restraining straps.
    6. Remove the core tubing retainers and lift out the core.
  4. To install:
    1. Install the core, then attach the core tubing retainers.
    2. Attach the core restraining straps.
    3. Install the housing cover, then install the two housing cover-to-air valve housing clips.
    4. Install the lower heater outlet, then attach the heater duct and lower side covers.
    5. On diesels, install the lower instrument panel sound absorber.
    6. Connect the hoses at the core.
    7. Lower the vehicle if raised and supported.
    8. Fill the cooling system.
    9. Start the engine and check for coolant leaks. Allow the engine to warm up sufficiently to confirm the proper operation of the heater.
    10. Recheck for leaks. Check the cooling system level.
Mar 07, 2010 | 2000 Buick Century
1999 cherokee sport, no heat- new thermostat and coolant help its cold outside
check the water control valve in the heater hose inline to the heater core
Mar 06, 2010 | 1999 Jeep Cherokee
Bmw diesel wont start in cold weather, i have
YOU MIGHT HAVE TO INSTALL A BLOCK HEATER TO OVERCOME THIS PROBLEM
Jan 05, 2010 | 2001 BMW 5 Series
Only cold air from my heater on e300 turbo diesel
The Most common Cause for your Heat to stop blowing, is low engine coolant. If there is not enough coolant in your system, your heater coil will not function. Check the level of your Engine coolant.
Jan 20, 2009 | 1998 Mercedes-Benz C-Class
Heater problem
sounds like you don't have enough coolant flowing into your heater core. Check coolant level in radiator and overfolw bottle.
Or, you have your temperature blend door stuck in the cold or partail cold position. Could be a bad blend door motor or heater cntrols head.
Dec 14, 2008 | 2002 Ford Windstar Cargo
Vehicle Parts & Accessories Logo
75 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
