Question about Milwaukee Hand Trucks Milwaukee 2471-21 M12 12V Copper Tubing Cutter Kit
How to replace cutting wheel in milwaukee copper cutter
How do i replace the cutting wheel
Need to disconnect water line at back of frig to move it temporarily while floor is replaced. Connected with compression fitting and ferrule.
You may be forced to cut the copper pipe and buy a new compression fitting and ferrule and add it to the cut off end of the copper tubing when you decide to re-hookup the refrigerator.
Remember to cut the pipe , if you choose to do so, with a tubing cutter so as not to "smash" the cut end.
This problem can happen any time dissimilar metals are joined, they can "freeze" together.
God bless your efforts.
Apr 07, 2016 | Freezers
My tube cutter won't cut
Mate sounds like the gear box is gone
If it's still under warranty take it back
If it's not get a normal brand non battery type you never go wrong
Jan 13, 2014 | Milwaukee tools Milwaukee 2471-20 12 Volt...
Copper pipe cutter not working
Replace the cutting wheel or the entire tool
Oct 05, 2013 | Plumbing
Copper piping? Tub faucets
1. Measure piping size with tape measure or read printed on pipe. 2. Visit local hardware store and take the faucet. 3. Tell them you need a tubing cutter and sharkbite adapters for the faucet you have. 4. Cut pipe with tubing cutters. 5. Push on sharkbite fittings. 6. Install faucet and supply hoses. 7. Take Bath.
Apr 28, 2013 | Plumbing
I have a Milwaukee CP12 12V Pipe Cutter. How do I change the cutting wheel?
I don't own pipe cutter but I have band saw. Just so easy to replace its consumable parts. Check this link . Hope that helps.
Apr 27, 2013 | Saws
What is a double wheeled pizza cutter?
a double wheel pizza cutter is a pizza cutter that has 2 wheels - one behind the other. The advantage of the two wheels is that they go through the pizza in one motion and you don't have to go back and forth to get a clean cut through the pizza.
Feb 28, 2013 | Home
What is the difference between a pizza wheel cutter and a pizza rotating knife?
A pizza wheel cutter is a metal wheel that rotates through the pizza so you can cut it even when it's hot. A pizza rocking knife is a thick metal blade with handles that you can use to rock backwards and forwards through the pizza to cut it.
Jan 10, 2013 | Home
Millwaukee portable band saw. We have been cutting metal closet rod with this tool for several years. The saw blades will no longer tension up tight enough. What needs to be replaced to regain the ability...
the tires could be worn, the blades mightt be a problem and underneath the front wheel there is a cam that might have the tang on it bent, to remove the wheel there are 3 torx bolts and under the cover there is a retaining ring to remove the wheel. the shaft connects to the tensioning lever and the tang on it should be straight.
Aug 03, 2011 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I cannot get off the abrasive cutoff wheel I put on the grinder
I believe the thread is left hand, but close inspection should verify. Also you should never over tighten cutoff wheels or grinding wheels. You should be able to remove with a gloved hand while holding button on top with the other hand
Dec 26, 2009 | Milwaukee Tool Milwaukee 6" Right Angle...
Milwaukee Hand Trucks Milwaukee 2471-21 M12 12V Copper Tubing Cutter Kit Logo
74 people viewed this question
Top Milwaukee Hand Trucks Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Hand Trucks Saw Expert? Answer questions, earn points and help others
