Fisher rs 717 diagrams - Audio Players & Recorders
Manual for Fisher model RS-9015
Try Googling (fisher)(RS-9015)(manual) without parens.
Dec 10, 2017 | Fisher Audio Players & Recorders
My fisher rs 929 front panel control board and tuner board has failed.Where can I source these boards?
I am currently working on a Fisher RS-929.It took a static
lightning strike through the antenna connections on the tuner board
what I have found so far is a blown coil, which I rewound, and
3 7812 voltage regulator transistors.if either one of these devices are bad the display(control board will not operate)I will keep you updated on this repair as I expect the replacement parts in this week. Hint:it is best to replace all three and check the two bridge rectifiers also. As these systems were built in 1996 it is doubtful
that replacement boards are redily available
Feb 21, 2014 | Fisher RS929 Receiver
Stuck in standby mode on Fisher RS-911A receiver
Does it power up or straight to standby? If it is on but in standby it could be speaker protection issues...check speaker wires and/or speakers for issues. If it's straight to standby and no power, it's repair shop time.
Jan 02, 2014 | Fisher Audio Players & Recorders
Connect LG NB3520A to Fisher RS-625 receiver
You would have to install a speaker selection switch. You cannot directly hook up 2 amplifiers to one set of speakers without destroying one or both amplifiers. Unfortunately, one set of amplifiers is inside your sound bar. An external switch would have to be installed on your sound bar as well as speaker terminals that would connect to your Fisher.
If you have a line out or tape out on your Fisher, and you have an analog input on your sound bar, use could use that as an alternate solution. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | LG NB3520A 300W Sound Bar with Wireless...
Fisher receiver rs 737
No answer, but...
I have a similar problem... I can power up my rs-911, then about 3-5 sec. later, it shutsdown (standby light still on)... What in the tarnation is going on? All 3 fuses are OK.?.
Nov 18, 2013 | Fisher Audio Players & Recorders
How do I reset a receiver RS-911?
unplugging is a hard reset for all new electronics,even if they dont tell you that. 10 mins
http://www.shopjimmy.com/
Sep 06, 2012 | Fisher Rs-909
Need fisher soundstage rs-929 manuals
You may buy the owner's and service manuals from here.
Jul 04, 2012 | Fisher RS929 Receiver
I have a Fisher RS-717 stereo receiver, amplifier. The speaker connections are channel A left & right and channel B left & right. The question is, can you connect speakers to just one channel...
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Nov 24, 2009 | Fisher Audio Players & Recorders
22 people viewed this question
 Grubhead
Grubhead
