Question about Jenn-Air JGR8850 Gas Kitchen Range
How to replace igniter
The oven doesn't bake anymore. Seems the bottom igniter has gone bad. However, replacing igniter doesn't seem to be a simple job to me. Back and bottom panels need come off first. Is there any suggestion or should I call for the professionals?
  • 473 Answers
Some are more difficult than others to get to. In some cases you will have to splice wires together. If you are not comfortable with this you should let a professional do it.
Posted on Oct 08, 2007
Broiler burns but the bottom burner on the stove will not come on the glow igniter turns orange but the burner doesn't light also one eye doesn't light, the striker sparks but the burner...
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
FOR THE SURFACE BURNER NOT LIGHTING The holes on the burner espically those around where the electrode are dirty/clogged. By using a paper clip/safety pin to push in and clear the holes then clean the burner up with some steel wool the burner should light. GENE
Aug 29, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
My oven will not heat-neither the bake or the broil. However, the stove top works fine. Could you tell me what might be the problem?
your oven ignitor has gone bad, its located at the bottom of the oven and tells the gas too turn on and light the oven, fairly simple to replace, once on has researched it online.[ youtube videos] i just replaced ours last fall a week before thanksgiving. i hope this helps
Aug 13, 2011 | Frigidaire FEF339E Electric Range
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
When I turn my oven on to bake it goes on and starts to heat up during the preheat process. As soon as it's done with the preheat & goes to bake a #3 comes on my display and the button pas does not...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Nov 23, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
The igniter was bad i replaced it with a new one (seemed simple enough) but when i put it on broil or bake the igniter doesn't turn red, is there something i'm not doing?
The igniter is in 'series' with the gas coil that operates the gas valve. The gas coil is probably bad. You can replace the coil not the whole valve. Go to repair and put in the model number and they will have it.
Nov 06, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
I have a JGBP30 gas range and the oven does not. Someone checked it and said the main control is bad. Is there a manuel that I could get or is there any way I could check it, before ordering a new...
Does the oven ignitor "glow" when turned on but no flame appears? does this model have an actual broil burner ? or does it just have a broil drawer at the bottom ? If it has a broil burner up top of the oven, does it ignite ? It could be the clock/timer, but rarely. If the "bake" ignitor glows, but the burner doesn't ignite, or ignites slowly and/or a "sputtering" flame, replacing the bake ignitor should solve the problem.
good luck
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Won't bake, but all else works
Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
Dec 22, 2008 | Kitchen Ranges
Jenn-Air JGR8850 Gas Kitchen Range Logo
365 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
