Question about Car Audio & Video
I have a CRATE BT50 bass amp and when I turn it on the volume just turns up automatically without me touching it. I would like to know how to fix this
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Replace volume Pot.
Posted on Dec 30, 2013
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Subs hit without volume on
1. Check Grounding system (Player and Power Amp).
2. Ensure your RCA cable is OK
3. You might adjust volume or bass volume on power amp to maximum, just set all to 50% while you are tuning.
4. Check the speaker out cables might contact the ground/ chassis
Mar 28, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
Crate bass amp bt220 limit led is flashing with the volume only at half
You can reach the limiting IRRESPECTIVE of where the volume control is set when you have a guitar or other source that has HIGH output.
Guitars that have battery in them with internal amplifiers are an example of a high output guitar. Plain inductive pickups may require the volume control to be set at say 70% to reach limiting.
Please NOTE that the volume control is NOT linear, but is an "audio taper".
Limiting means you are probably driving it too hard. Many learn the hard way when speakers and thee power amp fail.
When the cone is driven too far beyond the pole pieces of the magnet, then the IMPEDANCE of the speaker becomes relatively low and can damage the power amp. The limiter tries to prevent this by sensing the current and or voltage and will back off the gain internally. This causes distortion when it happens.
Dec 14, 2009 | Crate Music
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
No sound out of the Amplifier.
hello if you not even heard a low buzz en the speakers with all volume up is probably burned take it to rapier shop for a estimated saludos
Jan 08, 2009 | Audio Players & Recorders
Jenson touch screen head unit is all hooked up properly in a 2001 honda civic if i turn it up to around 25 with loud off and bass down it will shut off for a few seconds and then turn back on and repeat...
the onboard amp in the deck can't keep up and overheats inturn shutting off the speakers , this is common in jensen touchscreens esp the 9412 9512 and the uv 8 best thing to do is buy a 4 channel amp and the problem will be solved sometimes running a bigger constant power wire to the deck will help a little but not much better off buying a 4 ch amp
Aug 12, 2008 | Jensen Car Audio & Video
Buzzing bass Amp combo
The problem you have mentioned is a common one with old sets, but it also occurs in new ones also, though not frequent. You can fix this just by changing the electrolytic filter capacitors in the power supply and sub filters on the amp PCB. The new capacitors should be of the same or higher voltage rating and same capacity rating as of the existing ones. And as it is such an old one, it is better to change all the electrolytic capacitors to avoid any further problems.
Nov 23, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
