Question about Tools & Hardware - Others
I have a craftsman 351184200 that the Seal is bad , dry rotted and shatteres, is there any where I can order an aftermarket part?
The part number is 742400 in the sears catalog.
    New Friend:
  • 121 Answers
I have the part in stock.
Posted on Nov 26, 2013
Testimonial: "how do I order this part from you?"
How can I replace worn out grease seals on entire front and rear suspension system?
Check out ebay. I bought a whole selection of track rod style boots in a bag for which you select the appropriate size for your torn/rotted boot. Maybe someone does grease seals. I take it you've been to the dealer to see if the seal is a separate part number?
Nov 05, 2015 | 2003 Lincoln LS
My craftsman chain saw 18 will not start
The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Jun 19, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Why do my tires on my car loose air overnight?
There are multiple possibilities...
1. There are punctures in the tires.
2. The valve stems are rotting and leak air.
3. The tire sidewalls are dry rotted and leaky
4. The rims have rust or debris on the bead preventing a good seal
5. The tires were installed improperly, damaging the bead.
6. Someone is letting the air out.
Nov 13, 2013 | Cars & Trucks
Replacing bushings for the rear on a 2004 cadillac cts 3.6L
The howling is more likely rear hub
bearings- in wheel knuckle assy
Check for differential axle seal leaks
& check fluid level before that goes bad
I have a 2004 Lincoln LS with similar rear
drive & no problems with dry rot & it sits outside
Replace the worn parts
Try Rock Auto.Com & try for Moog Parts
The Stabilizer Links are shot for sure front & back
Mar 06, 2013 | Cadillac CTS Cars & Trucks
Craftsman 10" Bandsaw Tires
Your tires are available on www.ereplacementparts.com. They show two models with your model number in them so select whichever is appropriate.
Jul 18, 2012 | Sears Craftsman 1/3 hp 3.5 amp 10" Band...
Leaking sun roof. What is the most common reason for this? Is there a cheap fix for the problem?
This is a common problem for a lot of vehicles, usually when they are aftermarket. The first thing you will need to do is figure out whether or not you have an aftermarket or an OEM sunroof. then you can decide on how you want ot fix the problem. the most common cause for leaking sunroofs is that the rubber seal either shrinks from UVB exposure or it dry rots from UVA. Either way you will need to get a new rubber gasket if this is showing any kinds of wear and tear. next if the gasket is okay, then you need to see if the glass/ metal comver (depending on which you have) is deformed, or warped/ cracked. after looking into these two things you will have found something at that point. Then you just need ot make the repair as nessacary.
Jun 20, 2011 | Jeep Cherokee Cars & Trucks
My car sat for a year ,i stated it now and then,\r\nafter one day of driveing i seem to have a major oil leak from around the water pump sepantine belt area,any ideas please
When you don't run a motor for a while, the seals tend to dry rot. And then when you finally crank it up, the seal gets hot and expands, causing it to deterierate. Now the oil is passing right through that bad seal, causing a leak. Hope this helps. Please rate. James Booth :)
May 18, 2011 | 1991 Lincoln Continental
Check engine light on. I checked gas cap and it was not tight. Tightened it and light still on
If this cap was in fact the cause of the problem the car is designed to reset the CEL when a certain number of ignition cycles has been met without the original problem recurring. If it does not reset itself on its own then you'll need to look at the EVAP system for any leaks or bad parts. Common causes of that code are a bad EVAP solenoid, bad fiel cap seal, dry/rotted hoses, poor hose connections.
Aug 20, 2010 | 2005 Honda Accord
Dry rotted tires on riding mower. I can't get the
Try some penetrating oil around where the rim and shaft meet. Spray as far into the space as possible. Let sit for a little while to let the oil work. You may have to persuade it with a hammer.
Apr 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tools & Hardware - Others Logo
44 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
