Question about ViewSonic PRO8300 DLP Projector
Viewsonic pro8300 won't turn on
Bulb won't turn on
Over heating and shutting down
In looking at other forums I saw that putting it on the the energy saving mode helped I tried that because the bulb has hardly any hours and is still the original and the air filter is clean The energy saving mode worked the projector hasn't been shutting down
Mar 07, 2014 | ViewSonic PRO8300 DLP Projector
Viewsonic Pjd6531w bulb not turning on and projector requires unplugging to turn off
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 23, 2014 | ViewSonic PJD6531W Projector
Bulb not turn
bulb should stationary, not fault.
make sure bulb proper fit, push in hard, screw up, all covers on and screw, all cables correct insert, hours reset if exceed safe limit.
then google viewsonic pjd6251 projector manual
Jan 29, 2014 | ViewSonic PJD6251 Projector
Viewsonic ve155
INVEST IN A NEW MONITOR,IF OLD.
OR USE YOUR WARRANTY IF ANY.
Jun 19, 2013 | Computers & Internet
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
Send directions on how to change the bulb, please. Viewsonic model 5111
Please note that the appropriate replacement bulb for Viewsonic PJD5111 should have the type number RLC-047.
Instructions, including images, of replacement of bulb are available in the manual starting at page 43. For the electronic version, please see page 47 of this pdf: http://www.viewsonic.com/assets/035/9693.pdf
Hope this helps.
May 04, 2011 | Office Equipment & Supplies
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Mar 24, 2011 | ViewSonic PJD6251 Projector
Viewsonic PJ500 bulb does not come on
Hi.
Look at the base of the bulb at the filament in the center of the bulb, if buldging change he bulb first. If the porblem continues then have the units Ballast or Sometimes called the lamp driver check and replace if defective. The cheapest way is the check the voltage at the lamp connections in the housing for At least 280 volts, while turning on the unit you will need a voltage meter to do this.
Mar 03, 2010 | ViewSonic PJ500 Multimedia Projector
Remove cover viewsonic vx 900 monitor to change bulbs
How do you change the bulb on viewsonic monitor 19" model VX900? Where can I get a new replacement bulb?
Jan 18, 2008 | Samsung SyncMaster 550S Monitor
My ViewSonic PJ458D problem
This is known as 'cycling' and is common with mercury-vapor bulbs nearing end-of-life. When the bulb first starts, it glows dimly and grows in brillance. As the light grows, the pressure and temperature of the bulb also grows--increasing power demand. After a short while, the demand exceeds the ballast limit and the bulb extenguishes until the temperature (and pressure) drop again. Then, the cycle starts over. Bottom line: you need a new bulb (or, the correct bulb).
Nov 13, 2007 | ViewSonic PJ458D DLP Projector Multimedia...
ViewSonic PRO8300 DLP Projector Logo
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
