Question about Yahoo Diamond Vision DVDC803-04 DVD Player
Diamond Vision DVD/CD Player Model: DVDV 809-03
Just received this as a gift. Don't know where to plug the (3, Red, White and Yellow) wires in the TV. PLSE help.
They are Audio and video inputs that go onto the same colored jacks on the tv (if tv is too old, try using the vcr or rf modulator)
Posted on Aug 20, 2008
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
Trouble connecting my insignia 32in.Tv To my DVD player
Yes you can use Just the red,white and yellow cable from your dvd player to the tv....now make sure you have it connected correctly...sometimes its easy to confused the yellow and white connections. make sure your tv is turned to Input that you have used for connecting the cables on the back....such as...input 1...select input 1 on your tv....or if it says dvd...then select dvdv on yoru tv..You can use a HDMI cable...just plug HDMI from your dvd player to your tv and select HDMI on yoru tv..Good luck
Mar 08, 2015 | Insignia IS-LCDTV32 32 in. Television
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
Old JVC television model AV27220, serial number 10616951, chassis number A67, manufactured May 2001 - I lost connection with my CD/DVD player (Sony model DVP-NC615, serial number 1165211) for no...
The outputs from the dvd that you are describing are that of line level and not rf...so you don't need to tune the tv to anything..you just need to put the tv on the video source setting(video1,2,3 etc..)..if you have the remote..there should be an input buttton or a source button
Jan 07, 2011 | JVC Televison & Video
Mhow do you connect bt vision box cd player to tv
You must use a standard AV cable - one with 3 RCA jacks:Yellow for Composite video, Red and White for audio.
Just plug them in the correct connectors - they should be close together on the back of the dvd and the tv, clearly labeled.
Aug 29, 2010 | Arcam AVR-100 Receiver
I got this T.V as a gift and the DVD player stop working.So I got DVD/VHS player for it and now I don't know how to plug it in please help. All I am getting is sound and no images.I don't know what to do!...
Just connect the set of 3 round colored connectors on the back of the tv (Red, White and Yellow) with the same colored connectors from the back of the player - use a same colored 3-wire cable.
Jun 09, 2010 | TruTech T2000D TV
I need a remote control and i need to know how to hook my cyberhome to a tv. Its a use one
you need to purchase cable wire (yellow/red & white) at least 3 feet..yellow is video red & white is audio...plug into the color jacks on tv...the remote is kind of hard this dvd model is discontinued....
May 19, 2010 | Cyberhome CH-DVD 300 DVD Player
I hooked up a Diamond Vision dvdv 807-04 multimedia player to a Toshiba VCR via RCA cables; to an Emmerson analog TV which only has a RF coax cable connection. I get audio but a ghostly video that isn't...
This DVD player cannot be hooked up throught the VCR due to a copyright protection in the sofware. You must go direct to the RCA jacks of the TV and select that input.
Jan 04, 2010 | Televison & Video
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
Confused about Connections
Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
Yahoo Diamond Vision DVDC803-04 DVD Player Logo
750 people viewed this question
Top Yahoo Televison & Video Experts
Craig Butler
Craig Butler
Ernest
Ernest
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
